Who's cruising going down/ up to Browns Plains tonight?
I was thinking about it.
Stolen from Boostloosing. Tis pretty good not sure how old it is.
He came roaring down the milky way cutting crazy skids
Twas time to get the pressies out to all those eager kids
this year the reindeer stayed at home with the chickens there to roost
For santa modified the sled with an RB on full boost
with a 6 speed box and 2 way diff and a roll cage welded in
and a four inch straight through zorst with a canon from the bin
there was a bucket seat a momo wheel and a raucious screamer pipe
Santa dropped it back a cog and roared on through the night
twas lightning quick in no time flat old santa's round were done
so with time to spare he headed down the goldy for some fun
He chopped a bogan at the lights then mashed an RX7
no doubt across the 1/4 mile this thing could run elevens
He was cruising slowly round the spit and ran in to the law
with no mod plates and a screamer pipe he was in deep shit for sure
Name address and license please came the rude request from plod
Well up yours copper my name's my own and my license comes from god
At that old santa dropped the clutch and drifted round the rails
In the blink of an eye he was m1 bound heading straight for new south wales
2 motor bikes and an umarked car were hotly in pursuit
Santa turned the e boost up and gave the beast full boost
With the tweed in sight it looked as if he'd got away from plod
But a woosh and a bang and a cloud of smoke the RB dropped a rod
The law caught up and with pistols drawn they threw him to the ground
The sled was loaded on a flat bed truck and was headed for impound
A sorry sight did santa make as he sat there in the cell
oh why oh why did he ever try this christmas sleigh from hell
They crushed the sleigh and locked him away there'll be no christmas soon
there'll be no pressies for the kids cos santa is hoon.
that is Noels from 2008 he will be most displeased to find that some kent stole it without due credit :domokun:
there was also a sequel last year
Nice one Noel, gave me a laugh.
Anyone got said sequel?
It's got a second part.
http://www.sauqld.com/ipb/index.php?showtopic=2623
Thanks dood.
Merry christmas puppers. Santa will be back next year. :thumbsup:
I wonder what santa is going to do this year
+1. Keen for Part 3 :)
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
