Morning Mangs,
@Colon: Lucky bastard. Go home and get me some rum with your time off. Will bring you 2 bottles on thursday.
3 days to go for me :(
@Dan: Last day of sunshine today bro. Then torrential rain through christmas. Head out NOW.
oops too mant schooners at lunch, not sure wether i should try to work or just occupy the crease and minimise mistakes lol :domokun:
Love it and hate it at the same time.
The latter for sure.
+1.
So, apparently it is snowing in N.S.W. & Vic. In Summer. Must be a sign of the end of the world, I was so hoping for zombie apocalypse too :(
forecast for their area is not to come into heavy rain until saturday, tommorrow is sunny with possible light showers in the arvo.
Anyone know how far a car can be stripped but still be roadworthy / registerable?
Have gotten bored over the last few days and have ended up with no interior :unsure:
just strip the hell out of it, if questioned say you parked it at Logan train station and this is how you found it an hour later...
hahah, yer thats pretty true. just make sure you got lock nuts on or the game would be up ;)
so col? a 35 eh? care to elaborate?
i think holding back the smile as you told the story might give it away...
cause i would piss myself trying to pass it off as the truth...
2011 blue premium, expect delivery in March at this stage...
I should elaborate its not mine as in im not paying for it, but its living with me... :ninja:
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
