Hahaha I read that as 'will it bleed'
My response was going to be 'anything will bleed with enough force'
Morning :thumbsup:
Speaking of bleeding. Brisbane is currently bleeding a lot. The whole system is up the shit. 80 sites underwater, 10 or so washed away. HA ha ha son of rajab mayor says it will all be back online today.
Fat chance.
Morning Mangs,
Think I broke my finger again last night :(
Will it blend?
Blending has been done. I want to destroy it with some form of explosion...
LOL
Fat chance.
NG :(
I'm in here trying to fix it. Well making it look like I am.
Robin Lewis who is the CEO of QUU came in this morning to ask how the system was going. I answered pass to all of them. He laughed and then was slightly serious and asked how the system was holding up and who was fixing what. I told him how it was all stuffed and that we should fix it with fire and that I know a guy who would do it. He smiled and walked out.
It was after he left the room I was told who he was.
LOL
But that will make Jason's job harder.
Nah it'll wash all the poos away... yay.
Anyone want to finish off my engineering maths book? I have to hand it in on 3rd of feb.... i'll pay cash :-D and when i say finish it I mean correctly finish it off not just smear it with crayon.
I have to go back at the end of feb, you know INTO THE PIT ! (QUT)
My dad is currently in bris with a few blokes from his work (they are from sunny coast/unity water) trying to get the pump stations running again after the poop has gone everywhere !
