Morning Mangs,
Site managers first day on holidays so I've spent the first 2 hours photoshopping random pictures for the site foreman lol. I should probably do some work though...maybe.
Morning Fellows! Hows it all going? Hopefully chucking the new brakes on my car on Saturday or Sunday, been ages since i have done any spanner work. Looking forward to it! Even if it is an easy job lol
Mangs,
Sitting at Motor One waiting for them to tint a craptiva. It's a good break from how busy it's been today + the heat :thumbsup:
*waves out the window at Dan*
Well dont we have a cushy job :rolleyes:
I do
I rekon i do to as am at work and bored so reading SAU. And my boss doesnt give a f today either so great day.
So... anyone want to buy a new car :whistling:
Mangs
Playing COD
Busy day, so will get back to it.
As you were
WTF I pressurised my intake system again... all my piping seems fine. It seems like there's an air leak somewhere around the rear of the motor, on the turbo side, kind of around the back corner of the rocker cover. One of the screws there was half a turn loose so tightened that but realllllllly doubt that was the problem. I already packed up the compressor etc so I didn't check again but I doubt it did anything.
What other pipes run around the back of the motor that carry pressurised intake air??
Anyone have any opinions on this?
Yes I do
But I am looking at a BMW 535i, So if you have one of those it would be great!
Yes I do
well if you look at the cars i sell front on and they are in silhoutte then we would be close
It's F*cked.
:P
Sorry, pretty hard to have a guess at what's wrong over the interwebs.
The only hose that carries air towards the back of the motor should be the feed for the idle control motor... can't remember if this is pressurised or not, I think it comes of the J pipe though so I would guess yes.
My money is still on exhaust leak before the turbo or wastegate stuck open.
Andy,
Our garage is empty enough now, if you want to start to use your garage for your car instead of storage.
Andy,
Cool, You around on saturday? Might get it towed then? PM me your adress and I will start ringing towies!
I thought wastegate stuck open as well. But then again I don't have a big idea of this sorta thing.
Just realised new sau layout is mobile friendly. Yay.
Tappet cover gaskets will leak like a bitch when thos screws get loose (Which they always are) Tighten all the screws and go from there. My R33 has lots of leaks from that area and when i fixed it all up the car was much better behaved, Of course your gasket may be rooted too but try tightening everything first
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
