Morning Mangs,
TFIF. Wonder if I can get away with an 8 hour day today?
For Scott: Z32_ECU_Modifications_Direct_R33_Plugin V6.pdf. Booyah, V6. Please don't use the V3 one to do mine :P.
just keep a pair of baby socks in the car, fits perfectly over the gear knob and either stops it from getting hot in first place if you remember to put it on when parking, or protects your hand after the fact if you forget.
Hmmm i wonder what people would think if they walked past my car and saw my knob covered by a baby sock lol.
Very good idea but i think changing knob would be better as i never did like the one i got.
So I unhooked my wastegate actuator hose before work, went for a drive around to warm up (then a bit longer lol)
Anyway, hit around 10-12psi a few times (before backing off), but laggy, and can still hear a balloon squeak type noise.
Dump pipe on incorrectly?
Stock manifold (untouched when I replaced the turbo)
It's a split dump/front pipe, but not one of the shitty JJR ones, it's got a huge long split for the wastegate gasses. I also checked when I had it disconnected that the wastegate flapper doesn't catch on the interior of the dump (like on the JJR ones)... but that may have changed when I put it all back together..... I'm thinking maybe the gasket could be sitting shitty or something?
The wastegate is completely shut at idle.
so refresh my memory
you are getting no boost when everything is hooked up, but when you unhook the feed to the actuator you can get boost?
Probably a dumb dumb question but one I've never known the answer to
Does the diameter or length of vacuum hose make a difference? Specifically in this case intercooler piping nipple -> actuator?
Edited by mosquitocoils
Yeah I try and keep them as short as needed so that's good.... how about thicker/thinner? Any advantage?
Morning Mangs,
Success
Morn.
Stuck on a train. Plus side it's fark yeah Friday.
I'm on a trian, I'm on a muthaflipping train....
Too many knobs in that. Not my idea of a fun night out.
What turob is it? didn't you buy a highflow? It may have a balance issue....
Damnit, Nistune only posted this morning, won't get it till Monday now :(.
Still get to play with the software
Correct... Although I can still hear a squealing leak under boost
gasket or turbo is my guess.
sadface :(
This is for you.
oh and scarface.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
