cricket is a game i watch while drinking, not play for a competitive thing. I'll play drunken beach/ backyard cricket though.
Scott, really need a brumby box :(
Morning Mangs
We have a cricket team.
ooooo that is good.
But it is indoor.
Oh that is bad.
Um... what?
Pfft, its not really competitive. We take ourselves less seriously than the australian cricket team (and that's saying something ;)). Also there is a bar there, and you can get sloshed before you play if you like.
tehehehehehe... box...
Nuffing.
Maybe... :whistling:
Morning all
A likely story...
Sarp Mangs,
Busy Day.
Same. Busy day, busy week, busy few months :(
LaserRape update?
Erm yeah, this def needs to be organised before tomorrow afternoon if we are going tomorrow...
So I have another few days before I head back to Brisvegas. Once I'm back I have another week off work, time to get working on some simple stuff for my baby. Want to get the intake side of things sorted first, how hard is it for someone with limited knowledge to rip out an air box and replace it with a pod filter and a CAI for it?
Ridiculously easy - undo 4 bolts, remove box, insert adapter plate + pod together, bolt up
CAI = agi pipe and cable ties are your friend ;)
I really should own a 31 shouldn't I
So where is Scott? I expected him to chime in with some Lazercaust details
Dunno. He's probably nicked off with my ECU and Nistune :P
So strayan day today. Might have to design a CAI for the car.
Wait there's no beer in the fridge, no good.
N.G. :(
In short I beleive she is saying indoor cricket is strictly for homos!
Ahh I see. Furry Muff.
Yes you should :thumbsup:
I'll sell you a 31 ute ;)
Turbo is sent off bitches, was rediculously expensive to send express so its just registered post. Hopefully I get it back by next weekend...
Thanks Jezza. f**k people in cars eh...I saw a rear ender yesterday on Coro drive and was thinking f**k if that was me I'd be f**ked :pirate:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
