Hello IT
Have you tried turning it off and on again?
The button on the side is it glowing?
Yeah you've gotta turn it on.
Push the button!
<IrishAccent>
Ah! There you go. I just heard it turn on.
</IrishAccent>
What do you do?
Lots of stuff :P
Technically I'm a consultant working with engineering information management systems.
ATM I'm working on an upgrade project which is about 9 months work crammed into 4. Totally awesome :down:
My boss bought an iMac
I now have to support mac's OS on a windows domain
FML
Sucks to be you.
Urgh.
Didn't get much sleep last night because we lost power in the middle of the night. This set one of the smoke alarms beeping (they are wired to mains, I guess this one had a low battery or something) which woke me up.
When I managed to get it to shut up I couldn't get back to sleep because it was so f**king hot (no air con or fan with power out).
Feeling it about now :(
Sux2bu
Apparently we had a storm last night. Only time I woke up was to tell Sandra off for closing the window.
Someone provide me with the motivation I need to go to work. New job in 10 days, zero enthusiasm for my current one.
Get your arse outta bed and get to work you lazy fark!!!
It's like... eleventy billion degrees in the workshop today :(
Should work in an awesome air conditioned workshop like dan ;)
Sux2bu
I woke up at around 3 to the door slamming, brutal wind was brutal. I sleep well when it's raining.
John, still good for Saturday!
Yeah about 3am was when i got woken up. Got back to sleep at about 5, then had to get up at 6 :(
+1
see i have the window open when i go to sleep, that way you get fresh air. kyle thought it was your car alarm going off.
pulled a 'stray'n day today, sorting some things out
It's like twelvety billion degrees in Cairns today, way too tropical for me.
Watcha doin in cairnz?
I opened the windows when the power went out, I'm not an idiot. But without even a fan to move the air around it was still way too f**king hot.
Get Netbanking! Joo owe me rent money.
Also, can you swap my battery charger over to the other battery please?
For the first time ever in my working life I have two of these planned for next week (never chucked a sickie, only taken 3 legitimate sick days in the last seven years.)
Taking a half day to meet with the owners of the new pub I'm off to manage and a second half day the following day to get my baby serviced by Dan at ERD. The company owes me 460 hours of sick leave, they can pay me out 16 before I leave next Friday.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
