Balls up of a day at work. Total shit from go to woah. Every redneck trucker in Australia was in at the pub today, 3 bartenders and 400-500 people is not fun times.
Mangs. Timing belt success :cool:
Next up will be to replace some hoses and get some hotter spark plugs to try and get rid of the lag and idle miss. Then oil pump and fuel pump.
Then rear tie rods, boots all round, new rocker cover seal, and maybe a listing in the for sale section.
giving up skyline ownership?
or getting a different one?
Afternoon mangs.
What kind of euro you thinking John?
Pretty sure turbos are on the way out on the GTR the noise is getting worse and it sounds like Scott's now mellow.gif
Morning Mangs,
So narrows it down to bmw, merc, porsche, vw, audi, maserati, alfa, ferrari, lancia or a lambo eh John?
F1 was good last night even if Vettool dominated.
Morning Mangs,
'Tis the season for destroying turbos it would seem.
Knock Knock.
LOL!
At least it rules out the bloody french
They got the DRS zone wrong. Was too many free overtakes on the straightaway.
Other than that was a good race, for all the positions behind first anyway. Webbo needs to find some more talent, stat.
I lol'd at the commentators reference to Kobayashi "doing a Webber".
Yeah needed to be a bit later on to make it a bit more difficult and then all the passing would have to be done in the braking zone instead of before it lol
Yeah, they got it right the last couple of races but they messed it up this one. Cars side by side in the braking zone is what you want.
F*ck, too slow. Phone is already "Out for delivery". Damn DHL and their German efficiency.
Hopefully he either leaves it at the door, or gets back to the depot in time for me to go and pick it up this arvo...
And you know I hate Merc and Lambo, so that narrows it down even more!
If I do wind up going euro it'll be Alfa or VW.
Edited by Isola
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
