Morning mangs.
I <3 Boost classifieds. There's always some ricer selling parts cheap to pay child support to his three 16 year old girlfriends, or getting his VL commodore out of hock.
Morning mangs.
I was on there yesterday as a last resort, looking for Annas car.....so many dung heaps :(
Looking for parts for her? Or looking for her Sil to buy back?
Looking for an entirely different car for her, she needs room for stuff and is over old import shenannigans, hence a mazda 3 is on the cards.
Ahh, good luck with the hunt then!
Its turning into a prick of a hunt, all the ones we were checking out are gone, with not much to replace them, but who knows, a whole heap of them might be just around the corner!
And once you buy one, there'll be hundreds... always the way :rant:
Yeah, 8-10 is Matt Damon's birthday.
Not sure what other one you're thinking of though...
Umm john. How do you know it is matt damons bday then? You worry me.
    • I tried the next one up from 600k ohms which is 60M on my multimeter and all readings came out as 0.00 ohms so right now the most accurate is 600k ohms with only a 0.1 ohms difference between coils. Three coils read 1.4 ohms and the other three read 1.5 ohms.
    • surely that is a control arm, not a sway bar. In any case, visual condition should not be an issue, excessive movement under load (eg with a big pry bar) would be the issue. I can't see 99.999% of pink slip places even looking, let alone trying to test it
    • I attached the image of the only thing I found, nothing to do with ohms in the manual only torque values etc. However, being they are so close to each other I am almost certain they are good. Tomorrow I will test the spark plugs while I am there. and look at the ECU connections.
    • Hi Gents. Do u know what 18rim will fit under R32 GTST with no modification of current setup I have. I have buddy Club P1 17x8 on front and 17x9 rears and they fit well.   Will an 18x9 on 35 off set with 235 tyres up front fit? ON the Rears i can run the rim size n fit 255 or 245? or i got option to get 18x9.5 on 35+ Offset n 265?   CHeers
    • And, when measuring and getting <2 ohms, perhaps chose the next larger range than that, rather than something with a k in it!
