What needs to be done?
HT setup is now working like a boss
well..... i got an intercooler and a bunch of random pipes off Joe (guy in the burgundy R33 at the meeting on thursday night). from what i can see there is a pretty well full set of piping there.
I'm straightening out the bent fins in the front of the cooler, fitting it all. then painting the whole lot satin black with black silicone fittings to blend it all in under the bonnet :) so basically everything, and painting :rolleyes:
Morning Mangs,
Double RDO this week. Another death in the industry yesterday. :( Union will be looking for an even shorter week now.
Morning Mangs,
Cup bet placed. Going on my theory that the favourite never wins, I didn't put anything on Americain
Sounds too much like hard work :P
Morning Mangs,
Going to be weird walking past that building at uni now.
Morning Mangs,
Except for when Mkaybe Diva was a favorite 2 years in a row and took them both home :P but she is a pretty special case.
betting is fine at work. Their firewall is terrible/non existant. Boxed 6 horses for the trifecta. Hopefully it comes off.
Exception that proves the rule :P. Won't happen again for decades ;)
Mourayan was scratched! What is this sh*t? Might box up a trifecta to spend that money....
Or a way to lose it :nyaanyaa:
I cannot lose. It is unpossible.
The race that bankrupts the nation.
An assortment of incompetent politicians have already done that.
i wonder what will get more coverage today,
The Cup or the RBA decision
Cup, hands down.
A way to win enough money to buy a sim cockpit?
apparently normal race meets are far easier to win on than the cup! Most of the hardcore punters I know wont go near the cup.
The 31 boys at tafe bite real well when you ask them how's their pintara running :thumbsup:
Good form, keep it up :thumbsup:
Probably true
Probably true
Too many good horses apparently, at the smaller meets there is normally one or two horses that are head and shoulders above the rest. One of our mates is a horse trainer by trade, the bastard won $6500 one night while we were out drinking, even on a bad week he will make about $1000 out of betting because he knows all the trainers and horses. At least he pays for drinks when he is winning like that so I cant hate him too much!
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
