Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Fark all brah. School holidays so entertaining the kids. Taking them to the indoor playground thingo today, they fkn love that shit! Milf watch for me.
Sounds like a good day mang. I'm working till like 1 then we've got the work end of year touch football game/drinks/dinner so should be good.
For those that don't read my build thread:
OK, I've had my fun, here 'tis:
And for Colin:
No wait, that isn't right :D.
I only got 1 cat each side, the ones on the headers:
I think it has 5/6/7 cats in total, but the rest are further downstream in the exhaust system.
Unfortunately because the exhaust collects straight into a cat those headers are no good to me, so I guess its going to have to be custom headers (oh no, how sad)
It is the same engine as one of these:
But mine is not out of a GTA so it doesn't get the "GTA 3.2" stamp on the plenum
Also. the pallet had a mysterious white powder on one corner when I picked it up:
Dan tried it, he said it wasn't any good:
ATTN: Anyone who knows about trailers
My dad is out somewhere in the middle of f*cking nowhere, with his sailing boat on a trailer with pissy little 8" wheels on it. Apparantly the wheels have not held up well to the trip out there (and he still has further to go!), so he wants to put bigger wheels on it for the trip back.
He asked me to find out what the options are for him.
So whats the go? Are these wheels likely to be a standard PCD etc so he just needs to find bigger wheels with the same PCD. What would it be?
Or does he need to replace the hubs? Do all trailers have the same stub axles or does he need to find out what his has?
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :D
Edited by Smity42
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :P
Just for clarity, does he have a r33, or an actual boat on the back of the trailer?
if it is an r33, drive it off the trailer and drive it here.
If it is an actual boat, attempt to sail it here?
I accept your many thanks in advance
Martin - there are 4 and 5 stud trailer hubs. Most of the 4 stud are 5.5 INCH PCD which is ummm.. *counts* 140mm (as long as I've woken up enough to work out that math right...)
Any wheel will fit if it has the correct PCD, so he could put 13s on if he can find them. How big is the boat (weight wise) because trailer tyres have load ratings like car ones, so if he can work out what tyre he needs, he'll know what rims he needs. My suggestion would be getting tyres/rims that can handle at least half that weight again to take anything else on board into account (fuel, rods, air tanks, blah blah blah, you get the point).
That's really all I know about boat trailers, and it's been far too long since I've really has much to do with them, but hopefully that's SOME help.
The 5 studs I can't remember the PCD for though, so you'll have to hope he has 4 stud :)
Failing just living on hope you could get your Google on and show up that MUZT3K fuckwit :P
An actual boat.
Thanks for pointing out that lack of clarity in my post, it could have caused much confusion. Although, I wouldn't want to be towing a 33 on anything with 8" wheels!
Re sailing it back - he's going to lake eyre, there is no path of water to sail it back.
The boat is a tiny little sailing boat (monohull), weighs nothing. He has stacked up the trailer with supplies though, good point.
I've been getting my google on (instead of working) but so far I'm just getting more confused, i've found dozens of different 'common' stud patterns, and even a lot of 8" wheels that ARE the hub, ie the wheel attaches directly to the axle on a bearing.
I can't remember if dad's is 4/5 stud or if its a funky bearing one, I'll have to wait till he rings again because it's going straight to voicemail (he has to drive to the top of a hill and plug in his big antenna to get reception, lol NextG is shit)
Thanks for the help broseph
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
