Item: A Framed photograph that i have taken - which shows plane trails landing at an airport at sunset.
More info:
Picture was taken in Nice, France.
Image is framed in a lovely black flat frame, with bright white border.
It really does look beautiful.
The sky esp with a slight purple tinge really shines. Looks stunning. Will go great on any walls in your house or if you want at your work place!!
Perhaps this could be a nice present for someone??
Price: $180 plus postage Check for other options below..
Print size: 610mm by 410mm:
Actual image (What it will looks like):
My sig is not printed on the photograph. Picture is just for illustration purposes.
Please do note image has been resized a lot and compression has been lost.
Im not going to post my highres photos as someone might just copy it and take it etc etc..
Oh if you look closely enough you can see the windows of the plane :P
Framed photo image (how it looks):
Sorry will try and take better pics soon.. was in a hurry
Now if you want the different colored frames or borders etc.. i can do that :D
If you just want the poster i can print it alone too.. PM for price..
I can get the image framed in three different sizes with two different frame styles (box or flat).
Frames are crafted from quality timbers in a range of finishes. A white, off-white or black matte surrounds the print to emphasize my work and bring the piece to life. Premium ultra-clear perspex in front provides a superior finish and means the piece is lighter and easier for you to move without breaking.
Check pic below for different options: If you are interested in other sizes and what not, please do send me a pm.
https://www.sau.com.au/forums/topic/261461-my-own-photograph-framed/
You can now purchase all my other images online directly.
Please do visit my website (www.sidd-rishi.com)
Click on purchases and the rest is very simple!!
You can find out how the image will look like before purchasing too.. Eg) If you want it framed, it will show the final product.. so you know exactly what you are buying and how it looks etc etc..
Please do check it out :D
thank you
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
