Firstly, are there any ecu's on the market with an in-built fuel pump controller? Something that will regulate the voltage at differeing rpm, so the pump isnt running full noise 24/7 and heating up the fuel.
Main concern is big pumps in street driven cars.
I know aeromotive do a unit, but its only a 2-step i.e only regulates voltage based on 2 rpm inputs, well thats my understanding of how it works. Is there anything out there that gradually increases/decreases voltage in relation to rpm?
If you run a big pump/s, how do u combat this?
https://www.sau.com.au/forums/topic/261568-fuel-pump-controllers/
The ViPec/ LINK G4 just use two auxilary outputs. They are configured as fuel pump for one, to switch on, and the other is configured as Fuel Pump Speed. This is activated when a set revs is reached (and or %Inj Duty cycle ).
The switching obivously needs a relay with a resistor inline with the pump to be able to switch it in and out as needed. As in most factory efi setups for the last 20+ years.
Gary
You could use an aux output set to pwm to control the pump that way, but you would still need an external driver (ie ignitor module ) to drive the heavy current loads a pump would use.
Show me any ECU that can control pump speed out of the box directly.
And whats so hard about a relay and resistor ???
Gary
Gary
yeh thats the way i meant, use a pwm output to control the pump via a relay and resistor. in the haltech its got a 32x32 map for it aswell. need to discuss it with my tuner though
If you use PWM you won't be needing a relay and resistor, just an single channel "ignitor" would be necessary to controll the large currents possible.
The link can quite happily do this and has a 3d map based pwm outputs as well.... and you can specify what ever you want to be the axis's of said 3d map .... boost*rpm or %inj duty*rpm ect .....
Any ecu will need an external ignitor channel to control the pump.
So...... no need to ditch the Link/Vi-pec
Seriously, its really an impressive bit of gear.
Gary
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
