Item: JVC KWAVX810 Double Din 7" DVD DIVX USB iPod Touch Screen
Website:
Item Condition: Basically New
Reason for Selling: Need cash
Price and Payment Conditions: $700
Contact Details: Alex 0413005673
Basically Brand new, Only used once to test it out, Took some photos, and put it back in the box.
The great thing about this unit is that the face is detachable.
Plays all the files in the world.
5V preouts - Front - Rear - Sub
Easy to use Menu
Can plug in ANY usb device
READY for ipod, no need of extra box's :blush:
Can also add Nagivation and bluetooth to this unit.
Mobile: 0413005673
Please Only Pickup Now, I will not post.. sorry..
FEATURES:
Double DIN 7" TFT-LCD Touchscreen Monitorand DVD, DivX, AVI, CD, MP3 Multimedia Receiver with USB, SD Card Slot, Remote.
Features:
- Region FREE
- Proximity Sensor/ 7" TouchPanel Monitor
- Detachable front panel forsecurity
- MOS-FET 50W x 4 (20W RMS x4)
- Divx Ultra Certified
- SD Card Slot
- USB Port (AAC/WAV/MP3/WMA/iPodAudio & Video)
Specification:
- Power Output: 50Wx 4 Max.
- MOS-FET Power Amp
- Built-in 7.0-InchWide Monitor
- Proximity Sensor/TouchPanel
- Detachable front panelfor security
- SD Card Slot
- USB Port
- GIGA MP3 MULTI (allowsMP3 tracks to be playedback from a DVD disc)
- 192kHz/24-bit AudioDAC (DVD-Audio)
- 7-Band iEQ
- USB control for ColourScreen iPods (KS-PD100IPOD adaptor requiredfrom early models)
- DVD-Audio Compatible
- WAV Compatible
- MP3/WMA Compatible with ID3/WMATag
- DVD-R/-RW, R/ RW, VCD Compatible
- Multi-Border DVD Compatible
- CD/CD-R/CD-RW Compatible
- AAC compatible
- DivX Ultra / JPEG Playback/ MPEG 1.2 compatible (DVD/CD/USB)
- Bluetooth compatible withoptional KS-BTA200
- DAB control with optionalKT-DB1000
- 5.1-Channel DTS/Dolby Digital/DolbyPro Logic II/2ch MPEG DecoderBuilt-In Time Alignment (5.1ch)
- Gold-Plated RCA Line OutputTerminals (x 2 pairs)
- Gold-Plated Center-ChannelOutput Terminal
- Gold-Plated Video Output Terminals
- Gold-Plated 5V Subwoofer OutputTerminal with Level/FrequencyControl
- Second Gold-Plated Audio OutputTerminals
- Gold-Plated AV Input Terminals
- AV-BUS Input
- Detachable Motorised Slide-OutFace
- Multi-Function Wireless RemoteControl
- Dual Zone Function
- Headphone Surround
- Shock Proof Memory
- Headphone surround
- Shock proof memory
- Wall paper setting
- Amp defeat switch
- Steering wheel remote controlready (optional adaptor required)
- Rear view camera ready
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
