Reason for selling: had this for sale up on here a while ago but took it back off when i decided to keep it, also couldn't edit my add anymore so am posting a new topic. Have changed my mind and want a house instead.. After selling this car i will still owe around $8k in loans on it ><
Make: Nissan Skyline GTR, 1993, r32
Milage: 142,000 km's (about 6000km's since purchasing 2 years ago)
Colour: gunmetal
RWC supplied? Yes
Currently registered? Yes
Price: $20,000
Contact: PM preferably
Comments / Modifications
Engine was rebuilt 2500 KM's ago, Car is in VGC throughout, paint is in great condition, diffs and gearbox are also in great condition, all panels are straight, and engine is built for high power. One of the seats has a tear in it and this is the only problem i can think of.
Modifications: - Engine just rebuild 2500 km's ago at a price of $10400, I have full receipts
Performance:
Car has GAB Coilovers, standard rims with some decent tyres (+ a few spares of the same brand/size) and new pads/rotors.
Standard turbo's (replaced one with the rebuild because it was on the way out)
CP Pistons
Eagle H beam con rods
New main/rod bearings
bored and honed, surfaced, crack tested block
Linished and balanced crank
ARP Head Studs
Reco'd head, valves and reset valve clearances
New timing Belt
Adjustable cam gears
Tomei metal headgasket
N1 Oil Pump and drive
New water pump
New engine mounts
New tensioner and idle pully
Heavy duty clutch, cushioned so it's not a pig to drive but it will handle good power (800km's ago)
R33 AFM's
Twin *drift* pod filters
JJR Coil Packs
Has a 3" catback system with a hkz super dragger muffler, sounds awesome
Thick aluminium racing radiator
Full service including oil filter, plugs, coolant, p/s fluid
Audio:
a new Pioneer head unit ($300 unit)
exelsior 12"kenwood sub (was top of the range when i bought it a year or 2 back, sounds awesome)
a kenwood KAC-1204 amplifier (400 retail)
Also has original flare still.
It made 220kw on 10psi on standard turbos, turbos were never run over 10psi
GTAAAH Plates are included if you'd like them
Engine was built to handle good power, i had plans for twin 2530's and about 350-400awkw eventually but ended up in loads of debt so now i'm gonna sell it and get a home owners grant. I wish this exact car had been on the market when i was originally looking to buy one. It's in great condition, still looks stock (never been pulled over) and has a well built, strong motor to handle upgrades later (so you dont have to worry about another rb26 blowup)
I have done most of my km's driving to and from work, and have never taken it to track etc. THe previous owner used it for the same purposes and his wife used it for groceries (dead set, gtr grocery cart, blah)..
Edited by GTAAAH
oh and here i thought my plates were original :P engine was rebuilt by dom at protek automotive in preston, it's still under parts warranty and has a lifetime warranty if it is damaged due to their mistake
ur looks clean mate, ive seen u driven through altona meadows a couple of times and was just wonderin if the engine build made any difference in haw the car went as im rebuildin me rb26 now.
Hey mate don't think it was me, live in greensborough, theres a GTAHHH running around, same colour and everything it was probably that dude
The engine build didn't really make any noticeable difference in the way the car is, the cam gears dialed in will make a bit of a difference but as the rb26 is already a really well built and finished engine unless your stroking you will end up with the same sort of power you had before hand.. But instead of worrying about the car blowing up at any random time, you can throw some big turbo's on, crank up the boost and have a hell of alot of fun without worrying anymore, which is sick
I'll get some more pics of the car CeJay and throw em up tonight or tomorrow
  • 3 weeks later...
Will add a bunch of new pics tomorrow, this is still for sale, been very busy and car is just waiting on a wheel respray before its sold.. they got some overspray from something at some stage and the surface is a bit funny
New pics added
Will take some more tonight, i'm really bad at taking photo's, also car needs a wash, stupid rain where i work is always dirty
EDIT: Please note car is still for sale, i'm yet to have anyone actually come to look at it.
My Phone number is 0421654914, i work during day but i'll return all missed calls
No test pilot's, genuine interest only. Car is viewable at my house, am not meeting anyone elsewhere because of theft lately on these forums
Edited by GTAAAH
GTAHHH is on a black R34 GTR :)
bump, power steering leak fixed, much lighter steering now, i barely even knew it was gone, now it's noticeable as blah
got a compression test done too, results were 120 across the board, nice and close =)
Also got them to do a quick roadworthy check and it's all good, will get the actual roadworthy when i have a definite buyer
Edited by GTAAAH
some pics of the receipts, for work in the last 6 months
Car has only been used to get to and from work for last 6 months
I"m going to take some more pictures but hard to get time before it gets dark
Car has 0 rust, absolutely none, paint is in good condition, few tiny scratches here and there but awsome condition for a car of it's age
Edited by GTAAAH
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
