pics of front reo and headlights please.
sorry man,
headlights, both of em, and reo bar went this morning, few peeps came by, but still plenty other stuff avail.
If wanting other stuff and it is not listed, send pm , will try to help. found two sets of bov's for this in all junk in the boot.
no longer avail/sold, front and rear seat belts, also,
rear upper qtr window trims,
one steering wheel sold, one left,
Aircon pressure switch
gearstick rubber boot,
but still heaps of shizz avail.
  • Replies 85
update, sorry guys HKS pipe kit HAS gone
peloa, I've pm'ed you re the center dash aircon vent,
Hectic, pm'ed you re front bar, still avail, come and pick it up,
33apx, pm'ed you re steering wheel, only one left now, after Saturday,
fatz, just waiting on bank transferr to come through and the reverse lights'll be on their way, and
nzm031, same again and the aircon switch unit is off to you.
Still plenty other stuff, I am getting heaps of asks to dismantle motor and sell front cut separately, but really dont want to, how about somehow?? those who want stuff all ge together, pool the dollars, and take it awway, and then you all get to take off what you want??
Peeps are wanting stuff like: coilpacks, head, inlet plenum, turbos, alternator, gearbox, drivesahfts, I mena like heaps of stuuf is wanted, all I need is it to be gone, it is ready for me to pick it up and put it into your trailer, and it's goneski
tks guys
second gtr steer wheel sold, glove box lid sold, some interior trim sold, some still left, under radiator bov recirc pipe sold, reverse lights sold,
if anything you after ask away, still got fair bit of stuff left.
Sorry engine stating whole, got interest in it as a whole, so wont pull apart.
Diff and cradle soon coming out.
if the guy doesnt take the front bar let me know and ill come and check it out and see how bad the 2 cracks are
cheers mate
No probs, am haedin away over Easter to the Nissan Nationals, back on next monday gis a ring then to see if still avail.
The cracks are like 50mm long on either side below the headlights
front bar still available, gettin plenty calls, just gotta get up and come see it, move it or lose it, still gettin pms bout stuff that was sold awhile ago, when its cheep it goes pretty quick, check the full post comments for what has sold, still a fair bit left,
Pas door,
diff
cradle
tailshaft
rooflining
boot trims
frontcut with dash ecu gearbox loom
Pas door,
diff
cradle
tailshaft
rooflining
boot trims
hey man, I'm after a both window seal rubbers complete if in a good nic? How much?
Cheers
Dave :P
Cheers
Dave :P
Yep gotem, LHS as perfect, RHS has small cut 12mm long, but no rubber missing
$70 the pair, plus package and post of $20
Hi , talked to you at the Nationals , I've got the Black Aussie GTR. Chasing boot carpet, left hand vent and maybe bonett if GC.
Regards Brad
can u PM me details of the front suspension please mate and possbily a picture.
TRUST adjustable damper spring units still avail, along with other front suspension parts
pm'ed you
tks
hi man do you have the Trims - Rear 1/4 window trims and if so would you send them to WA ? $
I think I got what you want, left hand side for sure, can you send me a pic of exact what you need, as some bits are gone, postage to WA wont be a drama.
update, Sold items are:
bonnet latch, gtr "R" pedal rubberes
boot carpet
LHside dash vent
Also ready for pick up 4.1 ratio mech LSD diff, with shafts, and full rear cradle with suspension arms (no brakes), and tailshaft.
Front cut ready to be loaded onto your trailer too!
The back of the car is now gone, but we still have heaps of bits left, including boot plastics, rear bar, rear reo, tailights, fuel tank with straps, fuel pump,
Hey mate you got any stock bovs left?
Just after 1 without the piping as its for a gtst.
Let me know with a price including postage to melb if your interstate.
Cheers
Cheers
Only have one complete twin set available, it comes with the piping/manifolds on each side of them, $150 the lot plus $25 postage. If you need this, then buy the lot, and then you can sell off what you dont need, a couple others were asking for just the bov only as well.
  • 4 weeks later...
  • 3 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
