  • Replies 494
Posted Images
is the spit on every sunday just when ppl turn up
Yeah its on every Sunday, some more busy than others :)
Eweeeeewwww spit cruising
Hahaha too true, Though if I had nothing on and my car was "legal" I would prob take a spin through there
YOUR not whoring it up, that is whats going on, hehe ...
Needs more Gold Coast!
:worship:
Yeah yeah i knw but im a little more busy at work this week which sux major ass :D
I promise to get my whore on as soon as I get a chance . . . lol
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
