Just as the topic states, can noisey lifters enable r&r on a stock rb25det computer? I just notice that in my car sometimes it feels sluggish to drive after I have reset the computer and drove for about a week. On initial reset the cars goes like the wind and pulls excellently, but after about a week or so it just seems to lose that initial bite like the tune on it has been richened up. My lifters are noisey and I also have forged pistons, I just wanted to know if that could contribute to knock and cause the stock comp to go into the r&r maps.
Edited by Daboss
https://www.sau.com.au/forums/topic/264340-noisey-lifters/
YES. Having forged pistons and noisy engine will cause the ECU to revert back to the low octane low timing map and you will lose power because it thinks the engine is pinging.
There is away to disconnect your knock sensors and run a resistor on the line to trick the ecu into thinking there is no knock if you want to do it that way.
Search the forum, a mate of mine has got 280 - 300rwkw out of his stock ecu by tricking R&R and by disabling the stock knock sensors. his username is *RB2530* or something like that.
Do a search. let me know if you cannot find it.
https://www.sau.com.au/forums/topic/264340-noisey-lifters/#findComment-4519843
could be chocked up o2 sensor not seeing any airflow cos its coated in soot or just has never been changed
my 2 cents
then why does it come good after a ecu reset?
I did not know stock ecu's clean the afm's when they have been reset.
https://www.sau.com.au/forums/topic/264340-noisey-lifters/#findComment-4519873
I had a feeling that was the case, cause when I reset the ecu the car feels and runs like a dream, but as time goes it feels less and less powerful and my engine is kinda noisy with forgies. I found the thread, Thanks. Will look into this as soon as I have a way to monitor knock myself all the time.
https://www.sau.com.au/forums/topic/264340-noisey-lifters/#findComment-4519878
comp goes to factory defaults then uses the o2 info to tune fuel trims
o2 sensors are prob fine and just plugged up from soot
just pull it out and have a look
if its nice and clean its not the problem
if its full of crap then its overfueling clean it out with carby cleaner and replace and see what happens
https://www.sau.com.au/forums/topic/264340-noisey-lifters/#findComment-4520392
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
