  • Replies 58
Posted Images
matty if I do go, it'll be with 1 or 2 others and won't need room for camper trailer...........won't know until it gets closer & won't go if its raining
i'll post and let them know
after chatting with pitbull (one of the guys from the club) i can understand why............he was talkin bout cleanup after muddy track work. Got a bit to look forward to :lol:
Yup I'm keen!! Wanted to go to loveday for a little while now. Me and my swag :) Keen as to hit up some mud, if only I had better tires
The Suby wagon that made it back up had welded front and rear diffs and weighed nothing but was prone to regular break downs.
I have a lot of respect for those wagons after seeing a fairly stock one be put through it's paces a little while back
Edited by DR JOSH
ya want some good tyres, suss mine out (Kelly Safari Trex). Can get ya sick deals on them too :)
Matty I was eventually going to go for either the Mickey Thompson ATZ's (4 rib) or MTZ's
I checked the Trex but they don't look agressive enough to warrant the $$$........how much can you get them for?
I'm currently running 285 x 65 x 17 but will probably have to go 70 series due to availability.
Kelly Tyres
i'll put ya down josh
ya want some good tyres, suss mine out (Kelly Safari Trex). Can get ya sick deals on them too :P
Unfortunately tires foir the 4x4 arent too high on my priority list at the moment, well behind getting the DR tuned and I cant even afford that at the moment :D
Unfortunately tires foir the 4x4 arent too high on my priority list at the moment, well behind getting the DR tuned and I cant even afford that at the moment :laugh:
lol, that second half was aimed at pete not you :thumbsup:
Sounds good Matty....should know closer to the date.....hopefully not raining.
I'm guessing this is the place Loveday 4 X 4 Adventures
Saunders Gorge Sanctuary looks good to Dave and only 75km from Adelaide.
I ain't gonna stick my truck in no creek or mud bath though, lol!! :down:
u ant 4wdin unless its in a mud hole :P
i could check on a price for you for 17s tomorrow
can tell you that the MTZs arent cheap........i can get them for about 350 a pop for 15" (33x12.5x15)
u got ripped off if u pay 350. i paid 310 couple months ago. couple places i went tired to sell me them for that much n told em were to go.
mtz arrr F###in wiked tyres not to loud on the rd an handle bloody orsum. an i throw mine in any mud hole i can find an drive out of it 99% of the time
morgan is a great place to go with a group as u can all spread out an meet up quiet easy an theres sumthin for everyone there. only prob if u get keep in a standard 4bee u will bend side steps etc but heyy thats 4wdin
rob-beachport trip good for all levels great views an easy driving. no dowerns at all bloody good trip an can do it yr an yr again an still enjoy it
nice addition to the sig pete
my lift is done
you know how you said a 2" lift wont be a 2" lift
mine sure isnt..........i gained 80mm in height change :)
*edit*
pic
Edited by Matty 31
thanks bud, I'm glad someone appreciates it......not like some fish kid and his goober accountant mate :)
looks hawt with the lift.....they do settle a tad somewhat though and they recommend you check the wheel alignment once again down the track.........I assume your price included an alignment straight after fitment?
thanks bud, I'm glad someone appreciates it......not like some fish kid and his goober accountant mate :P
they're meant to settle a bit on the inital drive (and i remeasured this morning and they havent moved at all). alignment had to be done straight after as my steering damper had been changed anyway
car looks good matty,
i gave you a funny look this morning on south rd at tonsley.
i was in the new dark grey triton with a tandem trailer on the back.
also noticed you have hid's on low beam. as do i...
come up on the inside? that would be why there was an odd stare haha, toot next time
yep, HID hi/lo (solenoid controlled) in mine
  • 1 month later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
