  • Replies 53
got any more 4 door 32 parts for sale?? how much for the skirts posted to nsw 2323?
I will measure them up and sent u a quote this weekend.... What other 4 door specific parts are u after??
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
im also after 4 dr parts... wot do u have in terms of bodykit, suspension
4 dr side skirts are still for sale as are the Cusco castor rods, all the rest is gone..
  • 4 weeks later...
Still for sale
tubular bolt in 6 point roll cage with padding, plates, bolts. Came out of a D2 car from Japan, built for R32, not too sure what other cars it would fit into, possibly laurel/cefiro
$1000ono
R32 4 door type M side skirts, rare
$250pair ono
Genuine Cusco pillow ball castor rods/arms suit R32 gts/t S13
$250ono
Whiteline R32 front & rear strut braces, practically new
$320
R32 impul front sway bar with D-shackles & bushes
$100ono
R32 gtst manual standard computer, 93’ model, un chipped
$150ono
R32 type m front bar damaged on LHS,
$80 ono (pick up only)
Exedy Clutch Kit
This is a Heavy Duty Clutch Kit for the following:
Nissan Skyline RB20DET & RB25DET
R31- 1987-89 2.0Lt
R32- 1989 onwards 2.0Lt
R33- 1993 onwards 2.5 Lt
Purchased from CBA WA for $450
Clutch is practically new save $$
Clutch was used for approx. 2-3months on RB20DET powered Nissan skyline R32 with 210-220rwkw without slipping once. Very street-able clutch with good pedal feel (heavier than standard) and friction , clutch had a very easy life for the short period it was in my car (i don’t track or drift my car), data sheet that i have from when i bought the car says it has following specs:
clamping load = 2400 LB
faces = 2
Radius =7.625
Friction coefficient = 0.3
Torque = 457.6 ft/lb @ 4500 rpm
Horsepower = 392 HP
$250
RB20 clutch fans 1left
$40 each
Trust S15 exhaust and cat convertor. 2 parts held together with TRUST stainless clamp.
Has 'Jasma' plate on it (whatever that means)
Stainless rear cannon muffler (few scratches as seen in pictures but no dents)
Rest of exhaust and second muffler made from mild steel, painted in high temp matt paint.
Cat convertor is near new but is welded in place,
$700ono
Aluminium intercooler piping, lipped either end, 3” mandrel bent
$20 pair
R32 RB20 cam gears, standard parts, prefect condition, no wear on teeth, come as pair but may split
$50ono
R32 s13 front left lower control arm
$30
Nolathane ‘D’ shape bushes
Repco part no.
42150 (x2) 24mm ID/ 31mm OD
42937 (x2) 27mm ID /31mm OD
D shackles, for sway bar, tried to fit but never used, comes with grease sachet
$20
R32 ashtray with Apexi badge, rice up your interior with this fine specimen
hey looking for some rear suspension can u help me out for a R32?? cheerrsass
Sorry Jasmine, all the stuff that was for rear suspension has been sold. What exactly were u after?? Only have strut braces and bushes for a sway bar.
Cheers
Rob
  • 3 weeks later...
  • 4 weeks later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
