post-6290-1123088901.jpg[atta
c
hment=217206:180side.jpg]
Hey All since I just bought a S2 R33 my 180 is now up for sale.
92 180sx - 120xxxkms
Black - requires respray
5 speed manual
interior - pretty good 2 dash cracks
Mods - installed
GKTech 3in TBE and Manifold-standard turbo
GKTech front mount
turbosmart manual boost controller - 9psi
GFB Mach 1 bov
Flyn catch can
G4 coilovers - Just Jap - i find them stiff but never had coilovers before
JVC head unit
boston acoustics 6.5 components
cheap amp
cheap sub
greddy gear knob
Mods - optional extras available with car or separate
GKTech rocker arm stopper brand new in plastic $40
GKTech adjustable cam gears brand new in boes $160
Walboro fuel pump 341 i think brand new in plastic $140
thats all the mods i can think of atm - will update if anything else comes to mind.
Price as is $5k - rego ran out 12/4/09(Sunday)
Price with rego $6k - bloody expensive inst it!
Please no low ballers and no swaps
Contact Richard - 0431 812 935 or PM
Available for viewing after 6pm weeknights or anytime weekends.
Ok the reason i have listed the two price options is i thought someone may want it as a track or drift car and wouldnt need/want rego.
This has been my daily for 1.5-2yrs. It was to be my project but after doing the mods listed i lost interest and decided to stop building and use it as a daily - i commute so i drove it to the station and back 5 days and then what i ever i did on the weekends.
it is what i would call a doer upper, it is rough on the outside but has never given me any mechanical dramas - that said i do bugger all kms im 3min from the station - ive only done 15000kms in the 1.5 to 2 yrs.
Ok down to business. The main problem with the car is the body and yes i bought it like that! My original plans were full spray and widekit and then engine etc. There is some rust on the hatch -spolier holes. and the sunroof is dented in slightly and does leak with heavy rain - just park it on a hill and its ok - has been garaged since i bought it. There would be rust around the sunroof. I also nudged the front with another car so the front bar is abit screwed - not too bad its on but is scratched and flimsy.
Pics will be up asap today/tonight
Im trying to be as honest as possible and will add any other issues i think off - just thought of one - clutch sqeaks.
Cheers Richard
Edited by 1802NV
https://www.sau.com.au/forums/topic/265403-92-sr20det-180-5speed/
hey guys the paint actually looks better in the pics than in real life im no photographer.
If you want more pics or have questions let me know. i am after a quick sale but will not give it away. Also no test pilots. Cash or bank cheque and not really after an interstate sale but i suppose something could be worked out for a genuine buyer.
cheers rich
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
