Gotta few things to get rid of
Bosch 040 in tank fuelpump
Used for a dyno run,still in box. $100
Ba xr6 turbo fuel pump in skyline,silvia cradle
Complete ready to drop in with wiring etc
Used once.was new when put in
$100
Spats front strutbrace to suit s13 sr/ca,good condition
Only selling cos the 30det's too high to fit s13. $100
Speco 2" boost gauge in cup with sender hose. $30
Located in mt waverley vic
0431683303
Prefer MSG or call, never on here
Thanks
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
