  • Replies 58
Still lots of great parts available. pm if interested!
Intake manifold assay $300
throttle body chambers $300
intake plenum $100 (*NOTE* will do deal if all three bought together)
R32 stock ECU $100
Stock RB26 cams (inlet and exhaust)$100 the pair
Rb26 head (valves,lifters,shims,cams,cam wheels) late R32 GTR $1200
4WD sump (no gears but windage tray incl.) $200
Stock turbo's (exhaust man, dumps,O2 sensors and piping incl.) $500 the pair
OS Giken twin plate clutch (3.81mm meat left on each clutch/no grooves) $600
Crank,rods and pistons(Late R32) $500 the lot
R33 centre grill (2PAK metallic silver) $60
R33 front bar (N1 look alike/ in black base coat) $150
Located in Adelaide and can organise shipping if needed, at buyers expense!
CAN VIEW PICS THIS LINK http://s621.photobucket.com/albums/tt298/huliengines6969/
Edited by huli
R32 stock ECU $100
CAMS SOLD- PENDING PAYMENT
Legit offers will be considered!
Edited by huli
Hey ilija , do you know if the r33 front bar would line up with m-spec side skirts ?
if you mean line up as in level looking(around car) then "NO" a inch or so would be the difference.
Edited by huli
do you have the bit thats between the throttles and the head and holds the injectors in??
The intake manifold assay is what I believe you are looking for! And yes I have one for sale for $300 and postage would be $60(extra)to New Zealand!
Edited by huli
***UPDATED LIST OF PARTS REMAINING*****
-INTAKE MANIFOLD $100
-tHROTTLE BODY'S AND ALL LINKAGES $300
-R32GTR ECU $100
-Rb26 GTR HEAD (INCLUDES CAMS,VALVES,SHIMS,LIFTERS,VALVES,CAM WHEELS AND HKS SPARK PLUGS) $1200
-GTR 4WD SUMP WITH WINDAGE TRAY (NO GEARS) $200
-STOCK TURBOS (INCLUDES EXH MANIFOLDS,DUMPS,O2 SENSORS,HEAT SHIELDS ETC) $500 THE PAIR
-OS GIKEN TWIN PLATE CLUTCH $600
-SET OF RODS AND PISTONS $200 THE SET
-R33 GTST CENTRE GRILL $60
-R33 FRONT BAR (N1 LOOK-A-LIKE) $150
-RB26 CAM WHEEL COVER (STOCK) $500
-TURBO INTAKE PIPING (INCLUDES TWIN RECIRCULATION VALVES) $250
POSTAGE AND HANDLING CAN BE ARRANGED AT BUYERS EXPENSE(FOR THOSE NOT SITUATED IN ADELAIDE)
ANY INTERESTS IN THE REMAINING PARTS. JUST PM ME!
-R32GTR ECU $100
Can you send me a pic of the N1 Front Bar? Would you post to Brisbane? if so how much for freight?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
