18' Enkei + Hankook $1400 S14 Manual Kit $400 S14 Ganadors $400
5 spoke Enkei's + Hankook tyres
4x 18x7.5 +38 offset 5/114 good condition
4x 225/40R18 Hankook tyres Good condition
Suit: stagea, skyline, 200sx, mazda, ford, toyota, late sti.
Swap GTR offset 17-18-19 rims + cash adj.
$1400
S14 manual conversion kit
S14 tailshaft, speedo drive, pedals, master and slave cylinders, lines and damper, g/box mount and cross member.
sr20det used flywheel, clutch, fork and throw out.
No box, shifter or console surround.
$400
S14 ganador mirrors
genuine, electric, clear mirror.
painted black, missing 1x loom.
$400
Located Gold Coast
Sam 0423 648 114
Edited by RED513
FOR SALE
18x7.5 enkei + hankooks $1200
s13 + s14 bits
SOLD:
S14a 200sx 97 300rwhp @ one stage!
S14 Hks performer coilovers
S14 Hks/kawasaki rear coilovers
S14 manual kit, looms and ecu
S14 Whiteline adj sway bars
S14 KTS rear toe & front castor arms
R32 std rims
18x8 18x9 speedy cheetahs + federals
THANKS SAU
  • 3 weeks later...
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
    • Yeah sounds like the swirl pot isn't being fed from the return line, would be made even worse by the high flow pump.
    • This is the R32 one and the inside of the tank should look like this. which has an internal swirl pot, that the return line must empty into. (Interestingly, because the GTR tank is plastic it misses out on the swirl pot.) That is a potential cause for an aftermarket pump hanger to mess things up. Maybe the return is cut short and squirting over the side.
