Item 1: I have for sale 1 set of r33 coilpacks from a 1996 r33 gtst series 2
Coilpacks were working fine. i even coated them with silicone just to be double sure
Price: $150
Item 2: Turbosmart boost Tees (two of them)
these type:
Price: $50 each
Item 3: JJR split dump/front pipe - for r33 gtst.
had this on my r33 four door until it was written off. has a few dints on the bottom from car being too low other than that pretty good nick
Price: $120
Item 4: R33 stock side mount intercooler with shroud.
Price: $50
Item 5: R33 gtst stock front and rear swaybars
Price: $30 each
Item 6: R33 stock Dump pipe (Have 2) one with o2 sensor and im pretty sure one has front pipe also. one still has heat shielding on it
Price: $50 each
Item 7: Greddy copy plenum (chinese type) comes with all bolts, nipples fitting etc.
no throttle body adapter (can be had for $90)
I started to clean up the runners a little then my dremel decided not to work.
Price: $400
Item 8: Greddy Turbo Timer. comes with manual and plugs that connect to the back of the turbo timer itself. loom has been cut when taken out of the car.
simple job to extend them again with some new wire
same as this one but black.
Price: $100
I'm negotiable on most parts as i want them gone. will post smaller items and pickup is available for all items from Hillcrest, southside brisbane.
Contact via here or PM or Email: stephen. hendicott @ gmail. com if you want to call me PM and i will give you my mobile.
I will do my best to get a few pics up in the next day or two.
Cheers
Steve
Edited by stenve
https://www.sau.com.au/forums/topic/265789-massive-clean-out-all-parts-must-go/
Few Pictures:
Dump pipe is on hold at the moment.
more pics to come soon.
All the rest is still up for grabs.
Am negotiable on prices. so make an offer.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
