Every conceivable Skyline car can be seen this Sunday Michael, on the cruise from Internationl Regatta Centre at Penrith. 9.30am 26/4/09
It goes to Mt Wilson where there'll be Japanese swordsmen, Ladies in traditional Japanese dress, Photographers from Boost Magazine and High Performance Imports Mag, the latter of which will present Awards, Prizes and Certificates signed by Mark Skaife.
You're welcome to join Group #3 (=Non R34s).
This cruise is located on NSW subforum > Events > 10th ANNIVERSARY R34 GT-R thread by mxfly
If this doesn't wet your appetite, nothing will! hehe
Tez with a Welcome to you!
Hi hi, I'm new to SAU and i heard about the spit cruises, i already live on the coast but i would love to come see all the cars, is it on every sunday? and what times? i have a Skyline R33 series 2, 1998 model
you talking about the spit cruises at the gold coast man?
if so boost (boostcruising.com) have heaps of info - and pics each week from the cruise..
its a pretty good spectacle
every sunday without fail there is a big gather of the gold coasts finest and worst cars at the spit. if the police wouldnt exactly like your car then its wise to stay away because they usually pay everyone a visit.
my car "looks" stock as a rock, i don't want to spend money on apperiance when it ends up costing you more money been pulled over heeaaaps and WHY do i always get drug tested !!! i have even been asked how did i offord the car impling drug dealing, but never asked to look under the bonet
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
