With Ablett out for 3 (maybe even 4), it won't really make much difference against Swans @ home next week and NM (no Boomer) at home again the week after.......Doggies away the following week could be a bit tougher but I'm still backing the Cats in that one.
Will affect my already dismal super coach scores however!
https://www.sau.com.au/forums/topic/266313-footy/page/8/#findComment-4573393
  • Replies 515
Posted Images
only 1 real tough one in the tips this week....Crows vs Dogs.
If it was in Melbourne it would be an easy pick due to Dogs leg speed.
Dogs are coming here after 3 straight losses so they'll be hungry, Crows did OK against Cats & Saints but have only beaten sides like Melb & Freo (other than Pies) and have lost all 4 games at home, so they'll be hungry too.
I can see this one going either way.....apparently Bock's out with an injury now............I'm so confused!! :D
https://www.sau.com.au/forums/topic/266313-footy/page/8/#findComment-4582793
Brisb will beat Ricmond with no Mathew Richardson.
The rest of your tips look pretty good.
LOL, how pathetic are the current premiers this year......talk about premiership hangover!
Arguably the most dangerous forward line in the comp with Franklin, Roughead, Dew & Williams yet I'll never tip them again until 3 of them go and see Jenny Craig!!
https://www.sau.com.au/forums/topic/266313-footy/page/8/#findComment-4583370
was 18 points at 3/4 time or thereabouts. Was a wicked game to watch as a Bomber fan! Reckon i will be one of the few who tipped them but knowing my tipping i will still do shit lol.
Im 2 out of 3 so far, picked richmond to beat brissy, picked port to beat nth melbourne, not overly confident in that tip though.
https://www.sau.com.au/forums/topic/266313-footy/page/8/#findComment-4584365
you'd be surprised.....last year we had a girl in the tips that knew nothing about footy that got 4x 8/8's thoughout the year on weeks like this purely on selection by favourite colours :D
Happens quite alot. I'm never going to study the footy again. Im going to pick teams that I think will lose ffs.
If you look at my tips above you'll see I didn't go to well.
https://www.sau.com.au/forums/topic/266313-footy/page/8/#findComment-4585721
I lost the tipping comp at work last year in Rnd 22 because of this!!!!!
https://www.sau.com.au/forums/topic/266313-footy/page/8/#findComment-4585737
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
