Hi all. I'm on the hunt for a new front bar for my s1 r33. I currently have a top secret bar which is in need of replacing but the problem I experienced with this particular front bar is that it scrapes quite often. My car isn't lowered at all and it appears to be from the massive lip these bars have. Any recommendations for a front bar that looks the goods and is less likely to scrape?? Cheers.
https://www.sau.com.au/forums/topic/267093-help-deciding-new-front-bar/
have a look at www.carmate.com
im looking for a new kit aswell. i have the same as their T Style front bar, same problem as u... not too low, but still scrapes. im still gonna get a new 1 the same... i like it too much :P
I suggest you get the Do Luck kit...looks trick as...but if you want something simple and has a classic look, get the GTR Front Bar...
http://www.skylinesaustralia.com/forums/Mo...Sh-t267168.html
Hm I don't think I'd be doing the car justice by putting a gtr front, even though they look hot. The do luck isn't too bad. No scraping problems? JCaSs1001, be weary of carmate products. I've had friends who've been caught out by some of their products before
whatever you do, dont go the do luck if your worried about height, i recently installed a do luck and it came out far and sat low, i couldnt even get up my slight inclide drive, i switched to a 400R kit and havnt regretted it, its nice and practicle, sure it might scrape here and there but my car is lowered to so it can play that field to!
Dont touch carmate, quality is crap, fitment is way off got my from bar from them
As for kits the Do-Luck, 400R, Trust all sit low and on some driveways can scrape even with a car thats not lowered,
I got the TR Front bar, fitment was alright at the front apart from under drivers light there is a bad as gap...now my car was lowered like half an inch when coilovers were put in and cant get up a driveway with that bar...
MS Sports maybe
There is the JUN Kit, but preferably dont like it
Id go Do-Luck kit but thats just me
Is your GTR bar a rea lone or a copy designed to fit the r33 joey ? Is there decent urethane stuff out there ??
Gary
its a gtr bar for gtst in fibreglass....
the stock gtr bar can be made to fit, but you may need to pull your guards a lil
http://www.uniqueautosports.com/pricelists...arts/fr1bar.jpg
s1 style but opened up a bit more. if not there are a couple others on the site.
cant vouch for their quality though
my T style (like carmates) bar does scrap, especially when it was as low as i bought it... but as long as i turned on an angle it wouldnt touch...
thanx for the heads up about carmate.com ShyBoi!! ne 1seen the same bar in melbourne or another shop??? unique autos is pretty expensive by the looks of their site...
Edited by JCaSs1001
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
