Hey everyone, I own a VL with an RB25DET conversion. I had it shipped over from TAS a bit over 3 months ago, and I'm still struggling to get it rego'd! Took it to the pits, did everything they said, blah blah blah, and then I had to send off a form to get approval for my mods (very light - FMIC, 3" exhaust), and of course, the engine swap. Waited about a month and just heard back from them yesterday, they told me that they wanted me to get it Engineered, and here's the killer; emissions tested!
So yesterday, I took it to one of the engineers on the list that they supplied, and he was a great guy, and helped me, pretty much passed right there and then. Now all that's left is the emissions test. I've been told only two places do it that can be ADR approved, Kostecki ($450 base, and $130 every hour it takes), and Orbital Engineering (not confirmed prices as of yet). So I don't want to go there, find out I fail, then have to pay the $600 odd it takes to get a re-test. I've heard you can get emissions tests from normal workshops etc etc., for around $60.
So I was wondering, can anyone shed some advice on whether you think it's worth going for it straight away, or hunting around to find somewhere to pre-test? If that's the case, can anyone tell me somewhere that does the tests? HyperDrive unfortunately don't, and that's where I usually go.
My current setup is:
RB25DET
3" Exhaust (with what looks like the stock CAT)
FMIC
Pod
Can anyone tell me whether they think it's worth having a shot first go, because it doesn't seem like those minimal amount of mods would do much to bring it over the limit..
The things that the ADR test for are as follows:
- Carbon Monoxide
- Hyrdo Carbon
- Oxygen
- Carbon Dioxide
- Oxides of Nitrogen (Not to be confused with Nitrogen Oxide)
So after that essay, what I need to know is; Do you think it will pass as is? Or should I get somewhere to check it before-hand? And if that's the case, where can I get it checked?
Thanks for your time, really appreciate any help I can get.
Cheers, Joel :thumbsup:
https://www.sau.com.au/forums/topic/267606-emissions-bro/
http://www.dpi.wa.gov.au/mediafiles/lic_ib...ht_vehicles.pdf
It's only just become enforced now. When I got mine done the IM240 test wasn't available to the public at the time, so I was able to submit my test done with a scangas, but I heard they would stop accepting those once it was available.... Looks like you will have to do that test, which sucks as only Kostecki will be able to do it, as unless they have changed Orbital only do it on a commercial basis for fleet cars etc, it's not/wasn't available to the public.
The test itself doesn't take long so the $130hr I'd assume would be labour charge in setting it up, getting the car ready etc, so ask them directly just what is involved with that.
But however your best bet would be to get scangas style checks done to see how they are coming up, as it will be a lot cheaper if you need to do more do reduce emissions, compliance workshops should be able to help you out with that.
Good luck anyway!
https://www.sau.com.au/forums/topic/267606-emissions-bro/#findComment-4563313
Good luck anyway!
Thanks mate, any idea which workshops in particular could do this for me? That's why I'm so stuck, haha.
Joel
https://www.sau.com.au/forums/topic/267606-emissions-bro/#findComment-4563364
http://www.skylinesaustralia.com/forums/Co...hr-t191756.html
Pick one of the mechanical based workshops from there closer to where you live & give them a call to see if they do that sort of thing, but I heard you can get them from places like automasters too so maybe give them a call too
https://www.sau.com.au/forums/topic/267606-emissions-bro/#findComment-4563380
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
