1997 Nissan Skyline R33 Series II
White
5 Speed manual
120,000kms
Rego until November 09
I've decided to sell this car once and for all in order to get a bike or upgrade to an R34. This is a very clean car inside and out and is always taken care of with receipts and records where applicable. Timing belt has been changed at 80,000kms with regular services at every 5,000kms at JEM in Ingleburn. Gearbox and clutch is in very good condition, body is not too bad (chips on front bar from highway driving and usual wear), interior is very very clean. This car has just has it's major service done at 120,000kms (oil/oil filter/spark plugs).
I really need to sell this car because I'm always buying random things for it and end up reselling it again so reasonable offers will be considered.
Modifications are as follows:
Splitfire coilpacks
Exedy heavy duty clutch
3" catback exhaust
King springs
18" rims with near new tyres (265 rears and 235 fronts)
Xenons (hid)
Pioneer mp3 headunit
Alpine front speakers
Apexi turbo timer
Boost gauge
Pager alarm
Dark tinted windows
PRICE - $10,000 or trade for Honda CBRR 250 with cash adjustment
Call/pm/sms me on 0412 773 767
https://www.sau.com.au/forums/topic/267855-white-97-r33-series-ii/
Have a friend seriously considering this, however he has to sell his car first as well.
Market at the moment ain't great because of this recession. I might have to tell my friend to just let it go for a really low price in order for him to cut his losses and upgrade sooner rather than later.
I can totally understand. I will try to wait it out though, I'm sure R34s will still wait for me haha if not, cbrr 250 here I come!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
