  • Replies 137
  • 3 weeks later...
Dont think im too keen on driving the 34 down there however.
last major event i drove the 32 down there i was greated by a large number of port adelaide cops at a defect station just outside the entrance.
this year, ill be driving my mum's toyota avalon craimed full of people as they dont want to risk a defect either!
would have loved to enter for some more track time but cars STILL busted from drift prac :)
shouldve fixed that eh kye? :D
'should've' fix it, yes but then that would cut into important ps3 time ;)
nah its about 80% fixed, can finally drive it again. the wheels still hanging out the gaurd, think that it might have something to do with k frame or the f**ked bushing in the swaybar mount :s
it'll be ready next drift prac for sure though. been hanging to get back out there :P
