Hi guys and girls i do already have this topic up and running but i can't edit it to show pics and prices straight up of what i've got so i decided to start fresh, cheers
Item: R32 Parts
Website: Boost
Item Condition: Used
Reason for Selling: No longer have 32
Price and Payment Conditions: All prices are negotiable PM me
Contact Details: PM me please
R32 GTR Wing in original Gunmetal Grey minor chips underneath
$100 SOLD
R32 Boot Lid will fit GTS-T and GTR in original Gunmetal Grey 2 small dents on back
$100 SOLD
R32 Fuel Cap Cover in original Gunmetal Grey
$50
R32 Rear Pods in original Gunmetal Grey in good condition could do with a respray
$50 SOLD
R32 Rear Bar in original Gunmetal Grey few minor scratches
$80
R32 Right Hand Side Front Fender in original Gunmetal Grey in great condition no dents
$80
R32 Dash Cluster 186xxx k's in perfect working order
$80
R32 Door Fabs Complete with power window switches in working order
$80 each
R32 Boot Complete Interior
$30
R32 Door Handles in original Gunmetal Grey
$60
R32 Rear Tail Lights Original Gunmetal Grey Good Condition no scratches etc
$100
R32 Electric Mirrors still in good working order original Gunmetal Grey paint no scratches mirrors are good
$80
post-54752-1241168643_thumb.jpg post-54752-1241168705_thumb.jpg post-54752-1241168772_thumb.jpg
AP Engineering Apexi Power FC with hand controller for RB20DET
$1600
Bosch 040 Intake Fuel Pump complete setup for R32 GTS-T
$250
450cc Powerflow Injectors have been flow tested and cleaned less than 200k's ago were working excellent were making 258hp also comes with gtr resistor pack and fuel rail to suit RB20
$450
Gizzmo Intelligent Boost Controller 3months old perfect condition
$200
Whiteline Hicas Lock Bar also comes with block off line
$100
RB20DET manual gearbox has 180xxxk's gearbox is in perfect working order when removed from car
$500ono
pics if you need them just ask
RB20DET Starter Motor still works fine
$80
RB20DET Alternator still works fine
$80
RB20DET Crank Angle Sensor still works fine
$100
Nismo 62degree Thermostat has been used only a couple of months old
$50
R32 Power Steering Reservoir good condition
$30
R32 Radiator Coolant Overflow Bottle
$20
R32 Window Wiper Motor
$20
R32 Wiper Arms with blades
$30
R32 Seat Rail End Caps
$10 SOLD
R32 Flasher Relay in working order
$10
R32 Fuse Box
$20
R32 Rear View Mirror
$15
R32 Front Interior Lights
$15
R32 Ash Tray has hole in back from turbo timer
$20
R32 Steering Column Covers
$20 SOLD
R32 Left & Right Kick Panels
$25
R32 Left Hand Side Sill Cover
$15
R32 Left & Right Pillar Covers
$30
R32 Left Hand Side Door Rubber
$15
R32 Left & Right Door Panel Tweeter Moulds
$15 SOLD
R32 Centre Console
$40
R32 Centre A/C Vent
$50 SOLD
R32 Left Hand Side plastic mould that is beside the glove box closest to the door under the dash
$15
R32 Left & Right Sun Visors
$30
R32 Mould under steering column that covers fuse panel with air vent
$30
R32 Centre Console Surround
$40
R32 Glove Box
$25
https://www.sau.com.au/forums/topic/267972-r32-parts-galore/
  • Replies 40
hay
just asking if that Bosch 040 Intake Fuel Pump complete setup for R32 GTS-T will be fine for my r32 gtst just i have rb25 and what power can that pump take thanks
hey mate yea it will be fine even though ur running a rb25 coz ur fuel setup hasn't changed
the fuel pump is rated to 600hp
cheers
Hey Mate,
Im new to the site and Im trying to work out this forum thing,
Anyway would you take $1800 for the Power Fc, 450cc Injectors and the Pillar Covers?
Let me know.
Matt.
Please email: [email protected]
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
