HKS CAMP (computerised automobile multi player)
From the HKS website in Japan,
:"The HKS CAMP is a graphical data display created by a 32 bit RISC CPU. It records engine data with a large memory capacity. It then uses the data collected to allow for further evaluation and future reference. It can communicate with PC's (utilizing MS Windows 95) which allows users to drop all data compiled into their PC's spreadsheet for evaluation and graphing. The CAMP can also be upgraded by adding additional SRAM cards. The CAMP can be connected to all existing HKS remote sensors. A video signal switch allows user to change from CAMP to some other video source such as Nintendo 64, Sony Play Station, VCR, or some navagational system. The CAMP includes a remote control and sound functions for added convenience. With the sound functions, the driver can be alerted to changes in the engine, confirmation of different commands and operations, and entertainment."
functions available:
REV 0-10,000RPM
SPEED 0-300KPH
COST (FUEL EFFICIENCY) 0-20KM/L
FUEL USAGE 3000CC/MIN
INJECTOR WORKLOAD 0-100%
(CURRENT/PAST) TRIP FUNCTIONS INCLUDE:
TIME 0-99H 59min 59sec
DISTANCE 0-999.9KMS
FUEL USED 999.9L
AVERAGE FUEL CONSUMPTION 0-99.9KM/L
AVERAGE SPEED 0-300KPH
With a junction box, and pressure sensor, temp sensor and exhaust temp sensor, can be used for:
HIGH TEMP 0-1000 DEGREES C
LOW TEMP -20-180+ C
PRESSURE 500mmHg-2.0kgf/cm2 (BOOST)
VOLTAGE 0-5.0V
AIR FUEL MIX RATIO 10-20
ACCELARTATION RATE -1.5G-1.5G+
INFRARED TEMP -20-180 C+
ENGINE FRICTION GRAPHIC DISPLAY
More info on the HKS USA website: http://www.hksusa.com/categories/?id=1082
This unit retails for 39800Yen. It is brand new in the box. Will suit just about any Japanese car (ecu pinnouts for most included). Comes with all connectors etc.
Asking $350neg, in adelaide.
Attached is displays with basic CAMP unit
https://www.sau.com.au/forums/topic/26814-hks-camp/
No monitor, you can use any incar video screen - indash dvd, nav or something like the nismo centre dash display.
Only a few wires needed that connect to the ecu harness.
You need the HKS junction box and the harness for temp pressure and exhuast temp.
More info here: http://www.hksusa.com/categories/more.asp?id=1082
https://www.sau.com.au/forums/topic/26814-hks-camp/#findComment-565638
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
