Hey there have a r32 with rb25det in it. it has all the 20det manifolds and wiring. car ran fine after conversion bar turbo problem i stil have.
Car would smoke big time and cough and splutter trying to rev it up, 4gand max revs. oil in intercooler lines narowed it down to turbo.
So i got another turbo of a mate which gives same ish problems. test yesterday. wil idle fine, when you stab the throttle the engine dies and when slowly accelerating up to 2-3grand it will cough and splutter and smoke and not go any further cant 100% confrim what kinda smoke as it was at night.
Now so i go to run car non turbo to make sure it rans fine when turbo is not plumbd into intake and it wont start at all. put everything back to how it was and no luck. got good spark. fuel pressure at fuel line. im not geting fuel into combustion chamber. unsure on injector pulse but it started fine the day before.
i was thinking smoke and reving issue might be related to injector issure not fueling right? im not geting fuel into combustion chamber.
fuel pump primes fine. afm pluged in.
Just seems weird as it started the nght before but with symptons above.
any help would be great
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
