  • Replies 44
There is a whole heap of shit I need,
Dash surround
L/R sunvisors
ashtray
l/h door trim (down the bottom with the skyline written on)
the inside of the boot e.t.c
CHeers
PM SENT
pm sent
i may be intersed in selling my 5 speed gear box an fly wheel an cluch an all so have i brand NEW ikeya formula sequential shifter never been used owns me $2,500 looking to see if there is any OFFERS out there can do a good deal on bost gear box/shifter box has done only 66,000kms still look new if i get the right money i will sell it all
hey all i am now selling my CHEETAH alarm which cums with tilt sensor,central door locking,interior movement sensor, an lots more cost me over $1200 for the alarm an all the accessories
asking $500.............
hey here is sum photos off the alarm thanks
hey still got sum bits left
Hey I've still got door trims, back seat, seat belts, all the mouldings around the seat belts, lots of switches and stuff out of the dash, airdconditioner, condensor, engine fan and shroud, full wiring loom from front to rear, spare wheel and lots of other little things. Need all this stuff gone as it is taking up too much room in the shed. Offer me anything - even a carton of beer as I just might consider it. Get yourself bargain today! If most stuff is not gone by the end of the month, it's going in the bin!!! Thanks
cluster sun visors door strips kick panels door trim switches are all sold still got alot off parts in the shed thanks to all that have been helping me out buying stuff off me pm me if you need anythink thanks
Hi,
After the drivers side A-Pillar trim and trim piece under the steering wheel that has the cover for the fuse box (and some models the footwell light).
Both in dark grey colour (i assume all R33's the same).
Im in adelaide as well so hopefully can arrange pickup, as the a-pillar trim is a pain to send.
Cheers,
Kyle
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
