i got your dump pipe put in :D ... its good!! :) and yeah theres definitely a difference but i'm still running about 6-7 psi LOL ... gotta get a ebc ... i think my car is runnin much richer too ... got a question though ... i can't use the heat shield now with the dump pipe in there it will not fit in... theres no way to make it fit is there? so i think i may have to steal that CAI off ya :D also i think i may have to heat wrap the intake pipes LOL ... the other thing i did was put on the teins ... the ride is a bit bumpier but not that much ... i like it :D theres absolutely no body role and corners feel much easier to take LOL :D ... i think eventually your car will be mine steve LOL :D
https://www.sau.com.au/forums/topic/26945-attention-steve-d/
Sorry, no way you can fit the heat shield, thats why the dump was wrapped, to keep the heat down.
If you are only getting 6-7psi, I would expect that you must have a pretty restrictive exhaust - sorry to say. I had 9psi with cat and cat back, about 10 when the dump went on.
The main difference I found with the dump though was not increase in boost, but a really early spool up. I started making boost around 2200-2300 and the mid range felt a bit crisper when at part throttle.
I have the partition here, pick it up anytime. It may not fit perfect, but it would make a pretty good template so you could customise one for your car - easy to make AND CHEAP :D lol
Good to hear the tiens arent kidney jarring - sounds like the same one's Enrico has.
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573004
nah i dont' think its the exhaust being too restrictive .. i can't see how it can ... the only way to know is when i get the boost controller really :D .. but yeah the car is definitely 100% better especially now that i got a wheel alignment from bridgestone... free plug for bridgestone at mile end on henley beach road ... the guy was great .. cant' remember his name ... but i went to the one on gouger but it is closed due to renovations and the other guy said that that larry fella who all u guys love has left bridgestone and is now going to be working for the goverment?? ... guess hes following in steves footsteps :( ... but yeah now im taking corner faster without even hearing the wheels screech ... what a difference it makes!!!! :( ... the guy doing my car told me it was way off before he fixed it ... can't remember exactly what he said but it had 16mm toe in? or something like that?? LOL when it should be 2 :D hehehe
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573179
I am not sure about more heat wrapping, I only had the dump done and it seemed fine, didnt melt any wires or anything.
If you are worried just keep an eye on it, if anything looks like it is starting to show signs of heat fatigue, wrap it/shield it.
A bleeder shouldnt cost too much, and it will definately help, just dont wind in too much with the stock cooler or you will be needing a new turbo.
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573245
well to answer the second part of the question .. they did a 4 wheel alignment using their fancy hardware and computer :( ... notice quite an improvement ... in the morning my tyres were squeaking when i was turnin a little fast whereas in the afternoon they weren't squeaking at all :( and i was takin the corners a little faster since it was like 3 in the morning ...
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573832
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
