I got a bet goin for what my r33 GTST will pull tomorrow on the dyno. 4 blokes in $100 bucks each. All shit box commodore heads who have no idea im hoping to take there money. and yes we bet on anything. Whoever comes in closest.
R33 GTST Series 2 (65k on clock)
34SMIC
K&N Hiflow Panel
Nismo 3 inch & JJR Flow Split/Dump.
There putting in a new Turbosmart E Boost controller at the time and gonna give it a run on 12PSI. It dynoed before any mods at all (stock exhaust the lot) 158kW ATW. Although this time its on a different dyno so im thinking i shouldnt judge from that?...
Anyone care to give it a shot. Those in the know, what would ya go? (coz i got no real idea...) was thinkin around 175?
https://www.sau.com.au/forums/topic/269512-r33-gts25t/
Yeah, 12 psi id go anywhere around 170-175kw. My mates S2 R33 made 150kw on 10psi, but standard side mount & restricted exhaust still. Depends on how well you know your car, you could potentially see 180kw with some good environmental factors....with this colder weather id expect it to be toward the higher end of the range ur thinking of. Good luck with it.
https://www.sau.com.au/forums/topic/269512-r33-gts25t/#findComment-4588019
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
