Hey guys.. just getting ready to import my 32 gtr v-spec...
just wanted to know on a few tips pointers and what not... and what do we know about phoenix Imports. They seem very good, iv talked to them alot and they are very helpful and straigh foward just wanted to know any feed back before i dive in the deep end and give them all my moneys :) ..
https://www.sau.com.au/forums/topic/269596-phoenix-imports/
hey, PM me for more info
https://www.sau.com.au/forums/topic/269596-phoenix-imports/#findComment-4595160
Hi mate, I have personally gone through Az, his a nice guy who followed up on my request of a clean 180-sx and he did well. I will admit it took a while to get from japan to my doorstep but some things are out of the agents hands, and in this case it was the stupid customs process which added time to receiving my JDM import. All in all i would recomend this agent and his services, he explains in either detail or laymens terms to the customer what you want and what you would require/need for importation and other information.
I will probably be looking to import again through Az in the near future.
Cheers
Tom
https://www.sau.com.au/forums/topic/269596-phoenix-imports/#findComment-4595266
i got my completely stock r33gts25 through AZ about 2years ago now, great condition in all aspects
yeah it took a while but he deliveres what he promises and had good communication, i believe mine took quite a while to get through customs aswel.
But none the less great guy.
https://www.sau.com.au/forums/topic/269596-phoenix-imports/#findComment-4605350
just wanted to know on a few tips pointers and what not... and what do we know about phoenix Imports. They seem very good, iv talked to them alot and they are very helpful and straigh foward just wanted to know any feed back before i dive in the deep end and give them all my moneys :cheers: ..
Hope you have not gone to Phoenix Imports yet. There are heaps of others importers around.
But if you have, best of luck! You need that, haha.
https://www.sau.com.au/forums/topic/269596-phoenix-imports/#findComment-4616295
lol im guessing your a rivial or competing importer yourself..seeing as how you probably registered a new account to post your first two posts in this topic =]
https://www.sau.com.au/forums/topic/269596-phoenix-imports/#findComment-4616332
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
