hey i changed my plugs today to iridium plugs today and for the first couple of hard revs alot of grey smoke came out of my exsaust, and it smelt like metalic, any ideas? and my gs said when i drive off in the morning and it happens sometimes, befour the plug change
https://www.sau.com.au/forums/topic/270344-changed-plugs-and-grey-smoke/
Grey smoke is better than white or blue smoke. It just sounds like unburnt fuel to me, which is fairly normal on Skylines. It could be that the gap on the plugs aren't producing a clean burn when they're cold, so you could try playing with gap sizes. But I don't believe it is much to worry about.
would the gap being to big make it missfire? when it hits boost and a plant my foot it makes like a popping sound and sometimes you can hear and feel it missfire, i allways back off when that happens but could this be the cause?
Yes, plug gap and the amount of boost being run can often lead to misfire. The fact that expensive platinum plugs don't like being gapped is one reason I never use them, I prefer the coppers, as there cheap and can be gapped to suit the need. I've run coppers with 600rwhp, so there is no issue with them. A new set everytime I service it is a cheap investment.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
