They're not eligible currently, but theoretically they could be. Given that Y34s are off to a pretty slow start (which is unfortunate - they're excellent cars), I'd think you'd have a hard time convincing a workshop to take one on as a test car. The C35 Laurel on the other hand...
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4599985
are you having trouble finding a workshop for the C35 Kristian or were you just saying that its another nice car that will be eligible soon?
No problems finding a workshop to do the C35, just problems finding the article to make them eligible under SEVS. It may have to wait till my next Japan trip to test one and write the damn thing myself.
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4607435
  • 5 months later...
WHOA WHAT!!!!!!!!
JZX110 and now Y33!?!?!??!
THIS IS LIKE ALL MY XMAS's come at once!!!!!
ARGHHHHHHHHHH!!!!!!! so exciting!!!!! WHAT TO DO!!!!!!!!
hmm... zx110 interior = nicer...
but Y33 cima is sooooooooooooooooooooo amazing...
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4907654
I think I might know someone in Melb who would do it... time to start twisting some arms :(
WHOA WHAT!!!!!!!!
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4908211
Better chance of importing Lada's then workshops looking at models like that going on how screwed up it is at the moment.
Some compliance shops seem to be doing a LOT better than others and are still taking on new cars, hopefully I can sweet talk them. Maybe I'll have to buy the test car.. but then it can't be Bippu styles and that makes me a sad panda.
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4908937
Problem is they don't want to commit to the evidence costs or people preparing the evidence do not want to expend there money on a few peoples opinion, the Cube and EVO V are more value to a workshop over an unknown entity.
I got the Y34 on the schedule and they haven't taken off as they are so under rated which is why the evidence I have hasn't been used. I also have an F50 VIP Cima and both are later model cars compared to the Y33 which is another thing against them.
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4909184
I think the real problem there is, the Y34 and F50 jumped on the list right when our exchange rate went right down the toilet and the "GFC" (fvk I hate that acronym!) hit. Dealers didn't jump onto anything new, sticking with tried and tested and so they just didn't do much. I think if a few more were coming in, it would have a snowball effect.
Just my 2 cents -worked with the Aristo :blush:
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4909272
Just my 2 cents -worked with the Aristo :down:
When the Y34 was put on the schedule in June 2008 it was 100 yen to the AUS dollar as I also bought a Cube in July 2008, my F50 Cima was plated in DEC 2006 so the exchange rate couldn't of been the problem.
They are an unknown entity as well which takes time to build a following, remember how people hated the M35 Stagea and CPV35.
I drove a Y33 Cima on and off for 12 months, they are getting too old and tired compared to Y34's and F50's.
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4911361
I do agree that it takes time to build the following - this happens by guys like us getting onto them, getting them in and making people see how damn cool they are :( The fact that there's only a handful on carsales means people don't have a basis for comparison of different models and prices. Sh1t, I think I've almost talked myself into one...
https://www.sau.com.au/forums/topic/270361-y33-cedriccima/#findComment-4913045
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
