Hey this is a very regretful sale but I have to let my HR30 coupe go.
1983 HR30 Coupe, used to have L20ET, now with RB20 Conversion
Conversion is engineered and the car is currently registered in NSW, Rego runs out in June.
Hybrid Front Mount Intercooler Kit
2.5" Exhaust to Cannon Muffler
Pod Filter
HKS EVC Boost Controller
HKS Boost Gauge
Aftermarket "More Collage" Front Bar
Rear Seat has been Removed
Strut Brace
16" Watanabe Wheels
JVC MP3 Touchscreen Head Deck
7" x 10" 3 way Kenwood speakers fitted to the doors
Kicker 50 watt amp powering said speakers
ECU Talk LCD V2 monitoring screen (works really well)
Parts I have that haven't been installed yet
JIC DR30 Coilovers
DR30 Front Hubs
DR30 Front Brakes
6 Point Bolt In Roll Cage
Aftermarket Fibreglass Vented Bonnet (Needs minor repair and respray)
I also have 2 60l tubs of varous spare parts I have either taken off this car or collected from others over the years
Spare dash without cracks (current one has some small cracks)
This car is in good condition, the previous owner had fixed any rust problems and given the car a full respray with acrylic paint. Paint job isn't the best up close but still looks good. The paint on the bonnet is cracking and breaking up in places from what looks like a bog job before the respray, but I do have the spare aftermarket bonnet.
These pics are from previous owner (except for the one with the bonnet up and doors open), I will take some more pics once it stops raining here.
$8000 ono. This is negotiable please contct me if you are interested.
Mob: 0424 057 966
email: [email protected]
cheers for the pics, definitly an option for me at the moment.
will it pass rego etc?
Definitely will mate, if it runs out of rego before I sell it I will include a pink slip.
  • 1 month later...
  • 1 year later...
  • 4 months later...
Well I have had this on the market for a while, mostly my fault as to not chasing up interested parties. But I'm looking at a deployment next year and cannot bear to see her sit there unused anymore.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290509903330
Greatly discounted price. No reserve.
Hopefully she goes to a good home.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
