$1200ono
Im selling my 89' s13 Silvia Q's that has been in an accident as is.
The car was in an accident about 2 months ago where it has been hit in the front.
The engine had done around the 165,000k mark.
Was great car and i had no trouble with it at all.
Heaps of great parts available off this car.
For more info etc email me at [email protected]
I am located in VIC.
Edited by DannoV
Hey mate
wat engine was in it..mods etc?
Manual or auto?
Wer abouts in vic?
The engine is a CA18DE no mods
Manual transmition
And im in rowville (eastern suburbs)
Tried starting the car today with jumper leads but to no avail.
The car was in perfect working order before the crash a mechanically was fine.
The reason why it didnt start seems to be because the alternator might be busted, not 100% sure.
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
