Are you in Japan at the moment?
I will be in Nagoya tomorrow (In Osaka at the moment) if you are in Japan and want help finding the place, though with gauges it is generally cheaper to buy them from Australia, We have a huge range in stock from the BF series, Racer series to the Advanced gauges. Savings are made on over single purchases.
https://www.sau.com.au/forums/topic/273041-shop-in-nagoya/#findComment-4634330
dont want to tread on any sponsors toes... but you should be able to destroy Aus prices if buying them in Japan. Even if you pay full RRP. Shops arent usually the best places for good deals, compare the price of Slides stuff and work it out for yourself.
https://www.sau.com.au/forums/topic/273041-shop-in-nagoya/#findComment-4634530
Not that many shops in Japan always carry a full range of parts on the shelf, because most parts companies can ship out any part you want in a day or two at the most, so it's not worth them wasting the floor space or money.
The best way to do things is to print out a page from Defi's website before you go and circle the parts numbers of the ones you want.
If there are pictures on the page you can point at, that helps too, since the people in the shop will usually be worried about making sure you're ordering the parts you want.
After that, pay them in cash (which often gets a discount) and have the parts delivered to the hotel you're staying in. They should arrive in a couple of days.
https://www.sau.com.au/forums/topic/273041-shop-in-nagoya/#findComment-4634792
don't bother with Autobacs or Superautobacs... That shop is basically the Japan version of Autobarn. They only sell at RRP, and if they have a sale, its not much of a discount.
I just came back from Crystal tonight. The staff there is very helpful and WOW the prices are great (way cheaper then RRP)! Prices there are inc Tax, and if you buy a few items, they will give you a discount. I have 3 days left in japan, and I've spent 90% of my japan budget :P
https://www.sau.com.au/forums/topic/273041-shop-in-nagoya/#findComment-4635208
Thanks all......no I'm not in Japan at the moment but a short business trip might be coming up soon.
Obviously I know how much the stuff I need will cost to buy here in Oz, but figured that I may be able to save on postage etc.
Blitz....Is Crystal located near Nagoya? Do they have a website that you could point me to?
Cheers.
https://www.sau.com.au/forums/topic/273041-shop-in-nagoya/#findComment-4635405
crystal is in chiba near tokyo which is no where near nagoya. best off using streeter to buy you some on-line. just like in aus, in japan the cheap deals are on-line. get streeter to buy the stuff you want (he can even do it before you leave) then have him send it to your hotel so you can carry it home so save that $50 on postage. :D
https://www.sau.com.au/forums/topic/273041-shop-in-nagoya/#findComment-4635825
he's posted in this thread. send him a pm, tell him what you want and he will tell you the cheapest way to get it. he buys from yahoo and from parts wholesalers etc. you pay him a small fee and for that he will use his contacts to buy you the parts, send them to you and will save you some ¥.
https://www.sau.com.au/forums/topic/273041-shop-in-nagoya/#findComment-4636748
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
