hey everyone,
were wreckin out a complete r33 gtst,
HAs rear damage and light front damage,
101,000 kms ( service just done)
aftermarket wheel
nismo clear indicators
some lowered suspension
full brake conversion
kakimoto exhaust
STILL REISTERED,
immaculate interior
all doors and front guardsare good
ganador style mirrors
pretty much everything exept bearbox and pedal box!!
pm me if you need anything!!!!
FRONT LOWER CONTROL ARMS SOLD.
https://www.sau.com.au/forums/topic/273134-wrecking-complete-r33-gtst/
  • Replies 52
gear knob sold,
lower control arms sold.
motor sold
loom sold
ecu sold
turbo setup sold
front pipe and dump pipe sold
GTR pump sold
not separating ront abd rear brakes mate , sorry, rather sell as whole set,
cheers
Still have the alternator or did it go with the engine?
Haven't decided exactly what is going to go with engine package as it sold VERY cheap...
May have accessories like that still for sale...
Still plenty other bits available people, get into it :mad:
Hey mate, did the car come with ABS? Looking to install ABS into my Series 2 so I'm after the whole abs kit. Also, I'm chasing the little clip on the bonnet that holds metal arm that holds the bonnet up. Its the black clip on the left. Currently the only thing broken on the car and it annoys the crap out of me.
Hey mate,
I am after the front and rear brake pad shields (2 on each pad + shims). PM me if you fo not know what I am talkign about and I will send you a picture.
Do you still have the brake bits? Might also need the front calipers hard pipes connections(front). Are they available?
Eug.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
