Hey guys,
Following my thread with all the interior and engine bits, i have stripped most of the stuff out of the shell of my wrecked 32 gts-t. The shell is not reusable, its kinda banana shaped...but all the components are in perfect working order. Hit a pole directly into the drivers side door so driver seat and rails are out of the question. The rest of it is fine though.
I am now left with a rolling shell complete with ALL BRAKE ASSEMBLIES, COILOVERS AND SUPER TIGHT LOCKED DIFF.
Here is a bit of what is remaining on the shell:
- power steering pump
- clutch master
- full TYPE M brake assembly
- front and rear hubs, rotors and Type M 4-pot calipers with 1 month old Bendix Ultimate pads in the front and EBC's in the rear
- TEIN HR coilovers in good condition (height adjustable)
- Adjustable upper arms
- tight-as-hell R200 welded diff. Its welded, but its as tough and tight as a two way. Has got plenty of life in it.
- passenger seat
- rear seats
- all lower control arms, cross-member, Castor rods links, bushes, subframe
- handbrake assembly and surround. Leather was brought brand new not long ago, no rips or scratches. A good clean and it'll be brand new.
- stock sway bars
- HICAS lock bar
Prefer to sell the shell as a whole, with the purchaser picking it up from Chasers Motorworks, West Melbourne
COMPLETE ROLLING SHELL - $1500
Or in pieces:
TEIN COILOVERS - $700
FULL BRAKE ASSEMBLY - $400
FRONT ADJ UPPER ARMS $100p air
LOCKED R200 DIFF - $200
REAR SEATS (perfect doncition, no ciggie burns, scracthes or stains $150
This is a great drfit/track setup, would suit a ground-up project car perfectly, such as S13/180sx or another R32
PICS CAN BE SUPPLIED ON REQUEST
PM ME AS I WILL ANSWER FASTER.
SHELL LOCATED AT CHASERS MOTORWORKS IN WEST MELBOURNE
PARTS CAN DE DELIVERED ANYWHERE AT PURCHASERS COST
I AM SLIGHTLY NEGOTIABLE ON ALL PARTS, THE PRICING IS FAIR, NO LOW BALL OFFERS PLEASE
THANK YOU ONCE AGAIN GUYS :laugh::P
Sorry everyone, have been off for Long Weekend.
All PM's replied, most stuff is accounted for EXCEPT:
DIFF
DASH
REAR SEATS
Make me an offer ppls, this stuff gotta go my house smells like skyline
DIFF
DASH
REAR SEATS
$500 for the teins, if there not rooted from the crash???
cheers taras 0416355520
can pick up
hey Taras,
The coilovers are in perfectf condition, and $500 is a little too low.
The lock bar is sold pending pick up.
All the parts will be avaiable as of Monday, if the coilovers fall thru i will let u know, but i am looking for $700 for them, they are in perfect working condition.
Cheers
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
