well if u want to go in the GB i can do a full refund (paypal refunds fees also), might take 3-5 days to go back on CC, and u can get it later in group buy (probably start next month i imagine), or i can continue with it as normal and send it out by monday
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4654291
Hey all, just thought id add my bit;
I bought an Ecutalk cable of ebay for$60 and bought an adapter cable (also of ebay) to convert it to usb for $5, the converter cable was 1,5 meters long so when connected, the laptop can sit comfortably on the passenger seat. For me it was cheaper and I got a longer length than buying the Usb version cable.
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4656060
if u buy a serial ecutalk cable on ebay, before u pay send a message, say u want a usb/serial and one can be sent for extra $5 added to invoice. its the 'a111 usb serial' as mentioned in item description, 3foot long roughly.
the only issue with usb/serial converters is some of them dont work reliably (and FTDI based ones, which is the chip used in the usb cable, are expensive).
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4656166
is impul a daughterboard (still using stock ecu)?
as you paid with echeque itll take a few days to clear
http://www.filedump.net/cameronbnr/For_Sale/impulecu.jpg
-Overview-
- Better air fuel ratios
- Ups the boost a little
- Takes out speed cut
- Increases rev limit to 9000rpm
- Tweaked fuel maps so you can run more boost safely
- Plugs straight in, no other modifications required
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659792
Just read this.
Impul is just rechipped Nissan ECU even with Nissan part number for the tune...
Read out the image using EPROM programmer or consult and then that can be modified. As mentioned above either Dr Drift or a tuner with Nistune can do this for you... and use that as a base tune to work from
Those chips are soldered in so you will still need to get ECU resocketed
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659803
yep, assuming the consult code is still intact (in theory its possible to modify a rom to stop consult working, e.g. to protect someone from downloading your rom). fortunately i havent heard of any daughterboards/remaps etc losing consult capabilities (if anything only rom reading support, but even then most commerical tunes i dont remember hearing they disabled rom read).
so should be all good
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659827
I reckon I might get a V2 display & permanently mount it in the car.
:P
***edit***
Just bought one...
I picked up my new display unit from the post office today, plugged it in to the RSFV, configured the engine parameters for the trip meter and hey presto, I can now see how much fuel I'm burning :)
And as an aside, it shows all the ECU data just fine :)
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4662897
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
