Up for sale is my holden vt ss commodore 5.7 LTR v8,auto. this car has minimal performance modifications but still has alot of get up and go. It has an ss air induction, ss air flow meter, bigger throttle body 2 1/2 inch exhaust, and been dynoed at 217 rwkw. and she sounds pretty good to. The car has done about 126 xxx kms.
It also has slotted brakes 17 inch ROH wheels x5 (1 x spare mag in boot). It has dark black window tint, Also have a full fusion sound system consisting of a fusion head unit 2 front 6"s fusion 2 rear 6x9's and also a 1000 watt fusion sub and amp professionally installed by adelaide pro sound. I still have all the original exhaust and stuff like that to give away with the car.
The body is in great condition apart from a few stone chips on the front bumper but that is hard to avoid.
I have never had any problems with the car and i have had it for just over a year. My reason for selling her is just looking to upgrade and are open to suggestions for swaps looking to swap for a r33 skyline, also if the price of your skyline is higher can also provide cash your way
This car really is a pleasure to drive and im sure whoever buys this car will feel the same way, if you have any questions regarding the car please call or message me on 0433877496. *PLATES NOT FOR SALE* 14500 ONO MAKE ME AN OFFER.
pics can be seen on carsales.com.au heres the link cheers guys. PS i know this is a nissan forum site but am just looking to see if there is any interest thanks guys. I am located in adelaide, SA
http://www.carsales.com.au/all-cars/privat...ss&trecs=22
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
