I thaught i would re-advertise as a bit has changed.
1997 Stagea with ALL Autech 260RS S2 running gear, interior etc,
Motor was rebuilt approx 7000km's ago by Gavin wood Autotech, all parts mods etc 7000km's old.
167000km's on the chassis.
Excellent condition through out, beautifull car to drive, has the power and handling and is also happy to putt around. I use this as my daily with my 2 kids, awesome daily, unfortunatley its just not big enough, killing me to sell it, i got it built up as how i wanted it.
Details:
RB26DETT
Arias pistons
Eagle rods
ACL race series bearings
Fully balanced everything (crank, rods, flywheel, clutch etc)
Crank work (crack tested linished etc)
Block work (acid dipped, decked, crack tested)
N1 pumps
Tomie oil restrictor
Tomei sump baffel
Trust MHG
Trust 264deg cam's
All new genuine gaskets through out
New timing gear throughout
Head fully recon'd (lifters set for cams, guides etc)
New engine mounts, Gbox mounts etc
Platinum plugs
2 x Garret GT2860-7's
Apexi PFC (no hand controller)
Turbotech bleed valve
HKS pods
HKS tuned length front pipe
HKS catback
Stock dumps and GTR cat
New belts
Cleaned stock injectors
Walbro in tank 600hp pump can be supplied
ISC 52mm alloy rad (not fitted in pics)
Driveline:
New excedy cerametalic single plate clutch (rated to 330rwkw)
All 260RS driveline: mech diff, autech cradle etc
All new oils etc
Brakes:
New Master cylinder
Factory Autech 260RS brembo's
New Project Mu B spec pads
New rotors all round
New brake fluid
Suspension:
Nismo struts
Hicas breaker bar
New sway bar link bushes rear
New sway bar mount bushes front and rear
Exterior:
All factory Autech 260RS bodykit
Factory Autech rims with Kuhmo ecsta sport KU31's (3000km's old)
Fully tinted
new windscreen
Factory HID's
Interior:
Full autech interior
Trust turbo timer
Clarion CD player (dosnt work that well)
Alarm and central locking
Air con just regassed with new reciever drier
factory privacy blind and net
Auotmeter boost gauge in Mearcat pod
Car made 304ahwhp @ a little under 10psi. Limited by the stock fuel pump (hence the new walbro). Car was tuned at X-speed. They said with the combo on the car with the new pump, EBC and bigger injector you should see 450-460awhp @ 20psi ish, safley reliably, easily and responsively.
I have a HEAP of spares that can go with it.
I am chasing $33,000 ono
I will consider trade's/swaps for a 4x4 ute or wagon of lesser or equal value with cash etc or something S1X or R3X and the cash difference my way etc.
Im located in Bunbury WA.
0419943997
sorry for the crappy pics will try and get some better ones when its clean.
https://www.sau.com.au/forums/topic/273869-autech-260rs-replica/
This price is high as all hell. My mate just sold his genuine Autech with 550awhp for 27k.... Good luck getting anywhere near this price.
Thanks for the totally helpfull post mate. Much appreciated.
If this is Kens stagea your talking about im fully aware of that.
Thanks.
Will pay transport costs for any non WA buyer.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
