Hey everyone,
OK, I dont have a Skyline but im a guest over from perth falcons. An Intruder if you like :dry:
I've heard from a good friend that out on your cruises, you've been to the infamous truck stop off of Albany Hwy and that you have had to deal with that menacing bloke in the big ute that comes to ruin your cruise.
Its happened to me and some mates (not on a falcon cruise) twice now out of the 3 times we've been there, and frankly its pissing us off.
Does anyone know who this bloke is??? What his problem is and why??
What gives him the right to break up a car meet? Does he own the area or something?
He lives across the road and you will find he s the owner of the truckstop so you people are trespassing on his property so now you know why he gets pissed off
.... so now you know why he gets pissed off
Yes I do...but this is funnier
"All you teenagers GTFO...mmm that reminds me of the time we went over to shelbyville during the war, I wore an onion on my belt....which was the style at the time...you couldnt get those white ones, you could only get those big yellow ones.................now where was I........oh yeah, the important thing was I was wearing an onion on my belt, which was the style at the time, you couldn't get those... (trails off)"
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
