Hey guys, was wondering if you could help me and a mate out. We are unsure as to whether his Silvia (Q) has a CA18 or a SR20. So I was wondering if I could borrow your knowledge and help us out :) Here are the facts:
It says 2 litre on the engine casing.
It has SR20 on the sticker on the under side of the bonnet.
It says CA18 on the metal stamp next to the import stamp.
It is a 1991 model. (I think, it may of been imported in 1991)
We are unsure which to believe, the company in which he bought it from said it was a CA18 so it doesnt matter if it is, he didnt get ripped off or anything, we are just interested.
Cheers for any help in advance :)
https://www.sau.com.au/forums/topic/27412-is-it-a-ca18-or-a-sr20/
mad max:
Is the boot badge a circle or more square?
The SR20's have a circle, the CA18's have more of a square boot badge.
Also the SR20's have round halogen lights (99% of the time) and the CA18's have the better looking square headlights.
dkonig: Be careful not to spread misinformation.. SR20's have a red rocker cover, CA18's should have a silver one.
To confuse tihngs even more, it might be a CA18 with an SR20 Engine dropped in it. :)
But yes, '91 models and above are SR20's.. And no, it would have certainly not been imported in 91.
I have not spread any mis-information, the third silver rocker covered SR20DE I have owned is parked in my driveway.
silver rocker cover with distributor rather than coil packs is from S13 Q
S13 K had the red cover and the coils
LATE S13 K had the blck rocker cover with coils but NO VVT (not sloped at the back of the cover)
S14 had the black cover but sloped at the back for vvt
S15 sort of grey colour, also sloped at back
Attached a pic of my DE (and yes I know thats a turbo on it :)
CA18DE were all Red Rocker covers except for a CA18e which was a carby smaller version of the R31 pintara motor CA20e, the ca18e which had a silver rocker cover, but this motor was only ever a Single overhead cam jusst like the CA20e.
Guest Sphyncter
ive got a ca18de red rocker silvia. dont worry about the badging and stuff cause thats no good to ya. you should be able to go from the metal stamp (next to import stamp) because these are meant to be changed whenever engine is changed (duh!) because it should have engine number on it and stuff. i know mine has had a 2L in it at some stage, but its back to the 1.8. check the metal badge, if that says 1.8 then id say its 1.8. as the guys said, without a pick we can't help ya.
as for headlights guys, mines an 88 and its got the round globes, not the square!!
-Pat
And this has been my 2 cents.....
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
